- Apr 23, 2006
- 79
Went to crank the Bronco the other day, hit the switch and 1 click then nothing. Tried again - this time it cranked, no problem. Didn't think anything more about it til yesterday. Went to crank - hit the switch, nothing. Except this time - never would do anything. So I thought maybe the posts needed cleaning, did that - fired right up. Today, no crank. So I get out the voltmeter - 12.5 volts at the battery. Turn the key to on (not crank) and what?!?!? - the VM shows 6.8 volts. So I start poking around - if the voltmeter positive is on the battery post - 12.5 volts. If anywhere on the cable down to the solenoid - 6.8 volts. Turn the key off - 12.5 volts. I switched out the solenoid with another one - same thing.
Where do I start?
Key off
Key on
Where do I start?
Key off
Key on
