Like everything else I touch, I can't leave anything well enough alone. The amount of sludge on the exterior of the motor had me concerned, so I figure it won't hurt to tear it down and inspect it all.
A paper copy of the Cummins manual is around $150. After a bit of digging, I found a huge PDF of the thing online and downloaded it. It is like 500 pages and is detailed but easy to follow for the most part. Armed with a few nights worth of reading, I tore into the engine and now it is scattered in a thousand pieces on my work bench, on the floor, and across the garage...
The 4btswaps forum has been a valuable resource, but I haven't found anything on there detailing a tear down and rebuild of these engines. So, here goes!
Some of the more astute (or just paying attention at all) might see that the oil pan in the above pic was mounted with the sump facing the rear. It was originally facing forward. Yes, the pan can be flipped from the front to the back, as people say. The only things that need to be done are to source a new pickup tube (I swapped one out with a another engine) and will have to relocate the dip stick from the front of the block to the back.
There were 28 bolts with 10mm heads holding the oil pan on. Ok, there was also a lot of sealant as well. Nothing a small hammer and flat blade screw driver couldn't fix.
Got the oil pan all cleaned up. A wire wheel on a drill and a gasket scraper work well to remove all the old stuff on the sealing flanges. I will have to cut the pan at some point and clearance it to play nice with the Dana 60 front axle.
Seeing that tape roll reminded me of something. These things are totally new to me. I highly recommend ziplocks and markers to inventory all the hardware and misc 'stuff' as it comes off. I can identify just about any piece that comes off a Bronco. Not so much with this thing.
