My second Bronco... Crawler build...
Mountain Ram
Mountain Ram
Recovering Masshole
Abingdon, VA
Please tell me your garage was heated... it is too cold to be out there otherwise... specially for someone wishing for the stuff... :)
LOL!
Portable propane heat. Even without it the garage wasn't too bad. Too much cutting, grinding and welding- without ventilation- will shut ya down pretty quick.
tasker
all knowing of nothing
NH
KEEP AFTER IT.....haven't gotten anything done on mine
SC74
How about the c4 in the green machine... got her back in and running? I've got to re-install that C6 we talked about this coming weekend and make room in the shop %)
SC74
Any pics of how you did the front clip? My fenders and grill are welded together, but they still bolt to the tubed clip so they are still removable as one piece.
Mountain Ram
Mountain Ram
Recovering Masshole
Abingdon, VA
I feel your pain now... 10" of snow tonight- I wish you all had kept the white stuff to yourself!! LOL!
C4 is at the shop getting a rebuild. its been there about two weeks- I hope for it to be done this week. Of course with all this snow and lows in the negatives over the next week, I wont be driving the green machine for a while anyway.
I welded the fenders and grill together like you did Robert. The fenders bolt to the factory door jam location and then to the underhood tubing structure. I am dreading doing the hood now... I looked at how you did yours and although intimidating, I think that is the right way to go. Any tips or suggestions??
Monster Mike
Just buy a sheet of aluminum or polycarbonate and put a few breaks/bends in it. That's what I'll be doing to preserve my nice bronco hood. Polycarbonate bends/forms under heat and it also glues to itself very well.
No quick-latch treatment for the front clip!? Tsk tsk ;D
Yes pics of the front clip together Todd or it never happened!
Mountain Ram
Mountain Ram
Recovering Masshole
Abingdon, VA
Tell me mor of this hood idea... I can't picture it. My hood isn't that nice, so cutting it up isn't a big deal.
SC74
I wouldn't recommend doing the hood like I did. Although I like it and I'm proud of how well it turned out, I have way too many hours of time invested in it! I was in a "purist" mood when I did that and wanted as much stock metal as possible... Hence the stock bracing etc re-used. The easiest hood is to chop down a Fiberglass hood, but then you still have to either shorten the hood or lengthen the fenders... Pick the lesser battle of the two. I've seen both done well. In my case, I took a slice out of the hood just behind the nose.
Good Luck!!!
Monster Mike
Cutting it up isn't the hard part, reattaching it so it looks good and functions is.
Using the proper grade of Aluminum and bending/breaking it or some stainless...yeah polished stainless! Then tig the corners up real nice. Next make a sweet hood scoop! It will work as a hood brace too! Cheap and easy hood for the snorkel master! Don't forget to make a template first! LOL
Mountain Ram
Mountain Ram
Recovering Masshole
Abingdon, VA
Working on the drivetrain today. I have to work out drive lines and get a new rear ordered, but needed to fix the slip yoke situation. Running a 231/241 doubler- the 241 is a slip yoke type out of a Chevy.
Picked up a NIB SYE kit saving over $100 on new stuff!
Stock NP241
Rear output is 10.5" plus the slip yoke and Ujoint. The Bronco is too short for that.
New SYE installed... The shaft is beefy compared to the stocker, 32spline output!
This is a 1310 CV yoke, I will probably run a 1350 CV shaft from a superduty. You can see its 3.5"+ shorter to the middle of the Ujoint. Should help the driveshaft at max droop!
Mountain Ram
Mountain Ram
Recovering Masshole
Abingdon, VA
Wanted to make sure I gave a shout out to Mike at Trail Tech Fab. He did all the research and provided a modified 31spline input gear to install in my doubler to put it behind the C6.
He is a Tcase Guru and they have some nice gear. He spent a hour on two occasions guiding me thru my crazy idea!
englewoodcowboy
Lick Creek Restorations
Just say the word when it is in and I will come help get it installed. At least it looks like we are starting to head out of the white stuff so long as no one asks for more of it...
Mountain Ram
Mountain Ram
Recovering Masshole
Abingdon, VA
Mrs knows about them, just not the value of the contents!
Winters c6 rock gate shifter, new generic wiring harness and some misc cage parts I needed.
Mountain Ram
Mountain Ram
Recovering Masshole
Abingdon, VA
Torqued my back last weekend, so I'm limited in what I can do in the garage. I measured up the C6 output and the input side of my highly modified NP231. I will need to cut about0.600" off the C6 output shaft, but will still have 2" engagement on the 31 spline shaft.
