So, I have some accessories powered by an under dash relay. I ran a 8 AWG wire from the battery to the relay for it's main power source and I'm trying to get my switched power from a power source that is hot it both "run" and "crank".
From what I understand, relays use very little power to turn them on. I found the wire (shown in the photo link) from my ignition system that is hot it both run and crank, and I'm using it to turn on the relay. The problem I have is that it keeps blowing the 14A fuse pictured below.
My question is why on earth is it blowing the fuse? It should be drawing next to nothing. My second question is I've tested tons of other wires. Does anyone have a good power source under the dash that is hot in run and crank so that I can power up the relay?
Thanks!!
20190217_153937 by Jeremy Tepper, on Flickr
20190217_153908 by Jeremy Tepper, on Flickr
Thanks!!
