Well, where exactly would that be? Seriously over my head here.Did you take a temperature reading right at the gauge sending unit?
That shroud is for a stock mechanical fan, that's the problem and why I linked to the other fan like yours they sell but with the right shroud and then a link to one that would work but would take some modification.OK, that is all super helpful. Seems like I might as well try a shroud before switching to a different fan. Try the simplest, cheapest thing first. Is there any reason to not just use the Wild Horses one like this: https://www.wildhorses4x4.com/product/Full_Circle_Aluminum_Radiator_Shroud/Bronco_Cooling_Fans
or this
https://www.wildhorses4x4.com/product/17954/Bronco_Cooling_Fans? Maybe I need to call them to verify which fits this fan....
Someone also posted about an ebay option that fits with some modification, but one of these might be already the right fit?
+1 on trying that as well. It might pull paper but a fan is going to pull most from the easiest spots and if there's a gap, there is less resistance and will take more air from there and then through the radiator will pull whatever is left.Sure looks like a gap between the fan and radiator. The electric fan should be up against the radiator. The mounting hardware that came with the fan will mount it that way. Mine is against the radiator using the mounting hardware.
Tim
I've given up on any electric fan that throws less than 4000 CFM...I guess I'm just lucky.....I run that fan with no overheating issues.
That fan is a two speed fan.....I would verify it's wired correctly with controller. It should have two settings i.e. temps. One for low speed and one for high. When mine kicks on high speed while sitting in traffic I can see the temps start to drop. My ECM controls my fan.
X whatever on the IR heat laser gun. I have one and use it all the time.
Tim
Looks like 3.5"That shroud is for a stock mechanical fan, that's the problem and why I linked to the other fan like yours they sell but with the right shroud and then a link to one that would work but would take some modification.
Any idea where the fan was purchased from? If it was from WH, since they do sell that one, maybe they'd make an exchange or be able to get you the different shroud...not sure but at least worth a try.
In all honestly, it's hard to tell how much room you have and it would stink to buy a shroud that pushes your fan out too far and hit the water pump and not be able to use it, so be careful in your choice. The ebay one I posted is only 1/2" and the reason it worked for me and I had little choice since I didn't have room.
You might have enough room for a mechanical fan and that WH full circle shroud though and then not have to worry about anything.
Is if possible for you to measure from the edge of your water pump pulley to the surface of your radiator?
This:
Then if you do add a shroud to this, it would have to be a slim one, like 1/2".Looks like 3.5"
