70_Steve
Old Guy
- Dec 13, 2002
- 8,317
OK. So I'm getting around to widening my Exploder fuel rails to fit the 5.8 GT40 lower. Everyone else has just cut fuel injection rated hose, and used fuel injection hose clamps. But, now I'm looking at the stock Ford lines between the rails, and it looks like just 5/16 nylon fuel line covered with some type rubber coating (abrasion resistance???). I cut off the stock fuel lines this morning, and the fuel line part appears to be two thin layers of nylon line. There's no clamp or anything. The line is just pushed onto the barbs on the fuel rail.
Anyway... Just to be different, I though I might get a length of 5/16 nylon fuel line, put a couple bends in it, and slide it on the fuel rail barbs. Then I started thinking about the temperature that the fuel line starts getting soft. The install instructions on the repair kits say to just dunk the end in hot or boiling water to soften it up enough to push onto the barbs.
So, with the engine getting to 200+ degrees, does it seem like a bad idea to try to use the nylon fuel line? And if yes, how did Ford get away with it?
