- Aug 23, 2007
- 24,335
And this may not matter in the overall scheme of things, but just so you're aware, in mid-'74 when the 4-way flasher switch started appearing on the steering column, early models still had the original dash-mounted switch as well.
So if you're of a mind, you could give '74 it's own dash, or match it to the '73? Maybe list it as " '73 through late-'74" or something like that.
Just not really sure when the exact change came about where the dash mounted switch disappeared.
If I remember correctly, some members here with that combination have said that in those cases both switches were functional.
We have not tracked down precisely when the dash mounted switch disappeared, and whether it was a running change or if it was at the distinct break between '74 and '75.
But I'm pretty sure that early '74's were all the same as the '73 dash. Since the change to using a horn relay and the column mounted hazard switch did not happen at right at the model year changeover.
And why we have nightmares about sending customers the right parts for a '73, '74 or '75 steering column!
I have never seen a '74 with a hazard switch on the dash. Mine is 1st week of Jan '74, 1/3 through the model year.
