HotWheels
Rustytruck said:If you didn't live in a freeze zone I would bypass the radiator for your tranny cooler. But since you do live in a cold zone make sure you go through the tranny cooler first and then through the radiator. Make sure you have air pulling/pushing through the tranny cooler. If you are not using a 7 blade fan, BC bronco has a really good mechanical fan if it will fit but is noisy as hell. it will pull enough air. I run the factory 7 blade but use a smaller 289 water pump pully but its on a 302 engine. Gearing will help alot and will allow you to kick it in first gear and get the rpms up while going slow thus circulating the coolant much better. with out the proper gearing you dont have enough torque to pull the load so you just build heat in everything. Engine/ exhaust/ coolant /tranny everywhere. The difference is night and day running 4:11 gearing over 3:50 gearing when running 33's everything doesnt have to work so hard so you dont build excess heat in the first place. Especially since you live at altitude you dont get a break like flat landers do. When i fill a coolant system i run with the cap off and the front of the truck up on ramps or a curb so there are no low spots in the engine get, the system hot and full then cap it with a 16 lb cap.
so ur saying 4:11 is better than 3:50 with a c4 and 33s?
