P0300 cold start stumble
wesleydax
99 5.0 efi. after it sits for over an hour ish. It will stumble and almost want to die. Does this for about 15sec and then clears out and runs great. No throttle responce issues, ac compressor cycling on and off does not faze it. If you shut it off and crank it back with in the hour ish it starts great. I first thought battery may have been weak so I put the charger on it on boost and cracked it, same thing stumble and then clear up. It acts like its not getting enough amps/volts from the battery but when the alt kicks in it clears up. The only other thing i can think of is load test the battery at the cable ends to see if a cable is breaking down internally. Any body else have an idea of what it might be
wesleydax
wesleydax
Didn't know it had one. should the alt. be producing charge voltage instantly?
bronconut73
Yes But self energizing regulators do it or are supposed to do it at idle rpm.
The only reason I know this is because someone complained about there WH 3G alternator not producing any voltage until about 1100 rpm.
Paul jumped in and explained that it should be coming on sooner at like 750 rpm or something like that....
Of course WH took care of the issue. They are awesome.
Again....just another avenue to pursue. I am not the sbf efi guy here, although I wish I was, haha.
wesleydax
wesleydax
Thank you. I will take it off tomorrow and get it checked out monday
bronconut73
We should keep bumping this to the top.
Donk
Bowsher
Viper
Are all uber good with alternator, charging issues, Etc...
They also are good with sbf efi.
wesleydax
wesleydax
so if this is sinking in right. if i unhook the charge wire from the alt. and attach my test meter to the terminal i should get charge voltage on start up? I did load test the battery at the post and with a load it dropped to 10.5. would that be an issue.
bronconut73
Hmmmm......
If you unhook the charge wire from the alternator the engine may stall.
Modern cars need the alternator to run unlike older engines that can run without the battery after they crank up.
But yes there should be a way to see if you have proper voltage at idle rpm.
I have an Autometer volt gauge, but again yes you should be able to hook up an external handheld voltage meter to see what it is doing.
Remember it could still be something else.
We need to keep this thread alive until one of the sharp "old timers" chimes in......and they will if they see it here.
wesleydax
wesleydax
well it will run without the charge wire hooked up. Found that out the hard way, a battery will only last so long till your walking:-[. just went out and checked it and no wire to alt its putting out 2.5v but as soon as the wire is hooked back it goes to 13.74. static battery voltage is 12.4 and under starting load its 10.8. and of course it cranked and ran fine
bronconut73
13.74 sure seems fine....
Can't believe the regulars haven't chimed in.....
They must be out partying on Saturday night.
I'm on vacation;D
'99 is that return or returnless fuel rails?
Since the swap has it ever ran right, or is this a new problem to a previously well running swap?
Picture of the swap? (I'll be looking for unusual intake ducting or other odd looking issues) Did you use the same MAF as the donor (not equlivent as per the internet, but the same part and housing from the donor?)
wesleydax
wesleydax
returnless system. It has ran great for a coupe month since swap. It runs great now after the first 10-15 sec of stumbles,(that dont always happen) has plenty of power, idles fine. everything was swapped from the explorer.
Viperwolf1
electron whisperer
Pulled any codes?
Could be as simple as a dirty MAF or IAC.
I would say that, while 13.7 is normally "adequate" it's not really optimal for a modern Ford alternator. Should be more in the 14.5 to 14.7 volt category as measured at the battery terminals with the engine running.
And the self-energizing alternators only need a single blip of the engine rpm to bring it online. Where it should stay until you turn the engine off the next time.
If it's a normal internally regulated alternator, it starts charging as soon as the engine starts cranking as long as the energizing wire is connected and functioning properly.
You should not need to disconnect anything to determine how much is being produced though. Just read the battery voltage when running and that's your system voltage that the computer and ignition see as well.
Again... Assuming that all the wiring is good and that there are no losses in-between any key components.
paul
wesleydax
wesleydax
will be doing more checking today. it is at most 13.7 on voltage. would this be enough to maintain the battery over a long period
OK, another question.
Engine started and running fine. Shut it off and start right back up. Does it have the same problem? Or is this issue just after sitting for a period of time?
wesleydax
wesleydax
Shut it off and crank right back no issues. Normally sitting for over an hour will cause it but not always. This morning drove it to church sat for about a hour and a half cranked right back no issues. It will always crank and run just rough sometimes. I dont have a fuel pressure gauge but i cycled the key on and off a few times the off chance its pressure related but no change
