wesleydax
- Joined
- Apr 12, 2011
- Messages
- 331
99 5.0 efi. after it sits for over an hour ish. It will stumble and almost want to die. Does this for about 15sec and then clears out and runs great. No throttle responce issues, ac compressor cycling on and off does not faze it. If you shut it off and crank it back with in the hour ish it starts great. I first thought battery may have been weak so I put the charger on it on boost and cracked it, same thing stumble and then clear up. It acts like its not getting enough amps/volts from the battery but when the alt kicks in it clears up. The only other thing i can think of is load test the battery at the cable ends to see if a cable is breaking down internally. Any body else have an idea of what it might be
