After using the search engine on here I have come up with most of what Im going to need but wanted to double check with everyone here before I tear things down...I have read the tech article on how to do this but some links wear dead...I like to have my ducks in a row before I start....
This is what I have...
Engine= '71 302
Radiator= Stock Bronco Radiator
Brackets/timing chain cover= '98 Mercury Mountaineer 5.0
Harmonic Balancer= stock 302 (using a Driven pulley adapter)
3' body lift
With the above info this is what I THINK I need to get
-Carter P4070 Electric Fuel pump
-Upper radiator hose for '69 GTO w/400ci (Dayco #70480/Gates #20983)
-Serpentine belt Gates #8750k6 (not running A/C at the moment)
-Lower Radiator hose? This is where Im confused, I remember seeing some sort of pipe to run across the bottom and cut my original hose to fit?? The links are bad in the tech article
As I stated above Im using my stock harmonic balancer with a Driven Billet Aluminum adapter pulley for the serpentine belt...
Am I missing anything?? Or are the part numbers not correct??...Thanks in advance for any guidance...
Engine= '71 302
3' body lift
