I don't know much about fuel systems but don't EFI rigs have bigger fuel lines then carbed rigs. just a thought
Are you running an 80 psi pump for any particular reason?
As said, the regulator sets the pressure, so you're good with the 40-50 (I guess). I think it's supposed to be a rock solid 40 though, so not sure if that 50 will cause any issues or not.
And though pumps are meant to pump up against resistance to a point, maybe someone else will know whether running an 80psi pump against a 40 psi regulator is any problem or not. May not be an issue, but I thought I'd ask the question.
Sooo, I fired up the motor and unplugged the #5 injector and it didnt make any difference so I plugged it back in and unhooked #6 and ran worse.
So I unhooked #3 and then #4 #3 made it run a little worse but idle was still the same.
Think my injectors are bad? Cus that would make my mpg be really bad and run lean.?
I can't figure out how to take the injectors apart
