broncomitch
Valve covers will probably be ok but you'll need to route the PCV valve into one and run a small tube to the other. The tube needs to pull filtered and metered (needs to connect between the MAF meter and throttle body blade) air into the engine. Any unmetered air getting into the crankcase could cause issues with the A/F ratio. It eventually gets sucked up by the PCV valve and into the combustion chambers.
so run a line from the PCV to a T,run one to the upper intake and another between the MAF and Tbody? think thats how it was on the Tbird.
thanks for the help guy's
