think im going to warranty out my 02 sensors and try that..
Try this first...
http://www.ehow.com/how_6145181_test-ford-o2-sensor.html
Mitch brought his rig over the other day and we've been working on it. Here's what we found since the FP.
The NSS has to hooked to ground on his tbird setup. According to the wiring diagram it was supposed to go to a switched 12v. So we got that going and finally got the codes. It showed a problem with the o2 circuit. We got that fixed and all the codes went away except for the egr/thermactor ones which that stuff has been removed.
It actually runs pretty well now except.. Idle is rougher than it probably should be and even worse, he dove it around the block and coming back you could here a little backfire as if spark might have been intermittent and it would barely pull itself for a bit.
It was getting late at that point, and cold. So we'll pick it up in the day
light this weekend and see if we can get it to quit long enough to troubleshoot it. It's a lot closer.
-Steve
Glad to hear you are making progress. I've been following this thread but not much help from 800 miles away.
it's a flat-tappet with efi on top.Can't remember, is your engine a roller cam model Mitch? Or a flat-tappet type with the EFI upper stuff?
The resistivity/melting probably matters more when you have high amps, like a starter cable, but just thought I would mention it...
Eric
so should i keep the butt connectors?
ok...i think she's fixed.
THANKS STEVE FOR ALL YOUR HELP!!!!
