Power Steering Identification
jjintn
Johnson City, TN
The PO on my '66 added power steering at some point. From searching the forums I think it's a stock 73-77 box, but wasn't sure. The pump looks stock too, but the bracket is different than anything I've found from searching. Anyone know what I have?
Thanks,
J
Steering box is a '73-77 bronco box (6 turns is '73-'75, 4 turns is '76-77)
Pump is a standard Ford Thompson pump also of 70's vintage. Brackets holding the pump I cannot source, maybe bronco, maybe not. I cannot ID the bracket specificly. Pressure line has a compression fitting splice in it, that isn't right. That may indicate that someone used a different pump and pressure line and had to make a splice to make it work. That different pump may be from a mystery donor.
jjintn
jjintn
Johnson City, TN
Thanks for the info. Yeah, definitely noticed the leaking... most of it seems to be coming from the box side return line fitting, but a rebuild doesn't sound to hard after reading the walk through. Any idea if any of the chain auto parts stores carry a rebuild kit, or if not who has the best price online?
