Muddn7
Heres the scoop:
73 bronco with a 351W and 4 core rad. It has a large electric fan mounted in front of the radiator, and runs at great temps on the highway even with the fan off. I ran into a problem Sunday when my Bronco went out on her virgin run. The battery was junk! The alternator is new, and kept me running without a problem. The problem is, the battery wont hold a charge, so the fan didn't run at full capacity. Hence the 230 degree temp! The Ignition module decided to call it quits, so that added insult to injury! So if I kept her running, she would overheat, if I let her rest, I needed a jump! This was more than an inconvenience to me! Now were onto Monday: I replaced the module with a distributor carrying one from Mallory, new battery of better brand, and I emptied the rad and induced new water. I ran the Bronco up to 210 degrees in the driveway, then turned on the fan. The temperature dropped down to 190 degrees, and held it for more than 10 minutes. Then it decided to go up slowly. It reached almost 220 degrees when I decided to just shut it off before I pulled what hair I had left out of my head. So I have read up on the Bronco for problems and situations like this for years. I am on my fourth Bronco, and several other Fords in the process, but I had yet to run into this problem. Heres what I have come up with that might be a problem......
1. Its all water in the radiator! I have been doing leak checks, and if she keeps boiling over, I am not going to put radiator fluid in the radiator. The leak checks are good, but its an option.
2. The timing is factory at 10 degrees btc. The problem I might see is the pointer! It came off of a 302, due to my motor being without when I bought it! Can my timing be off?
3. Is the 351 just too much heat under the hood? With Hooker Headers, and a scoop with two exit holes towards the rear, I cant see it.
4. Now I am watching the volt guage, and its at 12, with lights on, and the rad fan going its at 11. This cant be normal is it?
I am just about finished with the build. I have more than most people like to admit already tied into this build, and getting very frustrated when I cant trail with it. If anyone has any idea on what it could be you would be helping me more than you could imagine!
1983 351W
Mallory dist
msd super 2 coil
dual flow water pump
Keep in mind that I even ran the heater on the 75 degree day just to wheel, and she still overheated sitting still for 3-5 minutes........
Thanks.... Muddn7
1983 351W
Mallory dist
msd super 2 coil
Thanks.... Muddn7
