Here is the transmission tunnel cover I made. It should be more quiet than a metal cover. The material is 1/4" Starboard. It is a high density plastic. It is primarely used in the marine industry.
Here is the pain in the butt stainless brake lines. They were not shaped even close to where they needed to be. With a little finesse, they are in.
Here is the radiator mounted. What a pain in the A$$!!!!! I had to cut the original mounting locations off, modify the new stainless top mounts and completly fabricate from scratch new lower mounts. I wish someone had warned me about using thicker than stock radiators and how they leave little to no room for a fan.
I installed new hydraulic pressurized hood struts. This is one of the few projects that went well and did not turn into a many hour pain project. I would recommend these to anyone. The were easy to install and they work great.
Here is the newly rebuilt original heater assembly installed. This also went well until I snapped one of the 4 studs off the back when mounting it. The good thing is 3 should hold it just fine. 30 year old studs are weaker than they appear!
That is it for now. I might start on the wiring this weekend. I hope the Ford electrical engineer across the street meant it when he said he would like to help.
Chris B.
