question about operating temp
tampabronco
In my 76 I'm running a reman stock 302 w/ belt driven fan cooling my OE radiator. I have 180 degree thermostat. It's a mall crawler and no off roading
During the summer months at red lights and drive thrus it creeps up to 200 until I get going
My question is 200 degrees is to hot?
-should I upgrade my old OE radiator?
I flush the radiator but still have some rust in there
-If I do upgrade radiator would a new stock 3 core be efficient?
Prefer a copper radiator
Yeller
Rogers County Oklahoma
200 is not too hot.
you'll get a myriad of answers but stock came with a 195 degree thermostat so 200 is no where near out of line. Many start to panic at 210, but as long as it is not boiling even 230 is not too hot, I don't get too worried as long as it will stay under 240, that's when the boil over begins, just be aware if your cooling system is not up to par boil over will happen much sooner so make sure your antifreeze mixture is correct, the level is correct, there are no leaks and your cap is holding pressure.
Scoop
Bronco Old Fart
Cuchara, CO
What Yeller said.
Mine hits 230 often on trails - long, slow, high altitude up hill runs. As long as it does not boil over you're good. 200 is not close to boiling without a pressure cap. With a good working pressure cap boiling won't occur until 240 or higher.
crankman
My 76 is used about like yours I replaced mine with a copper 4 core and my temps stay 1t 190 all the time moving or not.
Apogee
Tangent, OR
While I agree that 230F-240F may not be too hot, it's important to note that that would be at the extreme end of the "okay" range IMO. You certainly don't want to run there more often then not. That said, a 195F-205F standard operating temperatures would be totally acceptable...ideal even. Once you pass ~220F, your oil life shortens significantly and will require more frequent service intervals. Most of us don't have oil temperature information, so we have to infer whether it's too hot based on the coolant temperature, but oil life starts to fall off exponentially above 220F.
tampabronco
tampabronco
Good info
I'm thinking I should replace a 45 year radiator and put my mind at ease. Planning on taking a trip from Atlanta into the smokies next year
Scoop
Bronco Old Fart
Cuchara, CO
Agree. Mine generally runs ~200-210. The 230 I mentioned is just in extreme cases. But short spells at this temp has not resulted in any issues.
Good idea.
If it is consistant, it could just be error in the gauge.
If it comes up to temp, and holds a steady temp, that is great. Minor fluctuation based on load is to be expected.
When it just keeps climbing or the temp does spikes beyond the base temp with minimal effort, that is a cooling system issue.
Timmy390
Conway, AR
THERMOSTAT TEMPERATURES
Thermostats have a “rated” temperature such as 180F or 195F
This is the temperature the thermostat will start to open, give or take 3 degrees
The thermostat fully open about 15-20 degrees above its rated temperature
About everything I own that's EFI runs 210 on the dash gauge.
My EFI bronco has a 195 state and runs 200-210 but sees 220 now and then in heavy traffic/stop lights.
If you're using an electric fan and it's being controlled by thermostat keep in mind it's turning on/off so temps will go up and down and swing depending on the controller settings.
Tim
Yeller
Tim
Exactly correct.
Different application than most of you here, on you bronco anyway.... But my ECM doesn't turn on the fan until it reaches 227 and the tstat is 195. The gauge always shows 215 when the fan comes on and 205 when it turns off and running down the road at 190 and the fan stays turned off.
sprdv1
REBEL
Agree on 200 isn't too hot...
keep monitoring it for sure, just to be safe
