Radius Arm Cunfusion
J
jdavisjr
That was one of the first conversion kits on the market. Late 80s to late 90s. 2WD dentside steering box.
Strong box, but the inside the frame mounting makes for a short drag link. Limits articulation. But when this was common, articulation just didn't exist. This is the days of rock hard springs, multiple shocks, bright neon colors. Multiple shops sold it. Game changer when factory power steering boxes were getting rare and expensive.
Looks like the track bar drop bracket is only bolted on. Two things there. One is the bracket tends to move in the bolt holes, gets you a loos front end. Another is the drop bracket adds leverage and the extra load tends to crack the frame. Keep an eye out for those.
Reading everyone's input, I want to replace all of the steering linkage. What system is the best? Something like the James Duff, dual sport bump steer eliminator-tie rod over?
J
jdavisjr
And check your radiator. Mine had that steering box when I bought it and discovered the PO had made room by hammering in the bottom corner of the radiator. Needless to say it failed one day while on the road.
I just went to look at the radiator, attached a picture. Can get a penny in the gapo_O
J
jdavisjr
No off the shelf drag link for that steering box. Cut and shorten stock.
PNW
Start a new post for those not following this one that asks "What's the best aftermarket PS box"?
I've run 4 different boxes & they all worked & two of them weren't Ford Bronco boxes & they worked great.
There are different ratios that affect how many turns you have to turn it lock to lock.
Important- some people don't like the quicker ratio boxes & I think part of that is due to not driving it much & then that 1X a month when they drive it... it's not natural as it's too quick for them.
I drive mine probably 6days/wk (when home) & I wheel it a lot so it's not an issue.
J
jdavisjr
Thanks for the info. I will start a post on this subject
Correct.
Many years, many trails, many smiles.
(I'd have to confirm, but I believe it's the same box that's been on it all this time)
J
jdavisjr
When i drop the axle to replace the radius arm bushings, I should also replace the C-bushing. With the 3-1/2" lift, should the bushing be a 7 degree? Also, should I replace all the hardware to mount the C-Caps? Are there any other surprises that I might run in to?
Without reading backwards, do you know how much lift is on it now? And do you know how much caster it actually has now?
Knowing will help you to determine a good offset for the C-bushings. Not knowing, go with 7 degrees.
And hope that your front pinion angle will not be too severe.
I'll re-read later to see if I have a different answer.
Yes, that means I should not have posted an answer at the moment! But since most EB's prior to '76 seemed to have too little caster from the factory, we've often defaulted to 7° bushings in a "just in case" scenario.
It's also why we usually recommend that you get an alignment readout right from the beginning, so that you know where you're starting from.
J
jdavisjr
Thanks Paul, Can I take it to any alignment shop, or does it need to be a specialty shop? If I just drop the 7 Degree in what issues could I except?
Yes, any shop that has a standard rack that can handle most vehicles, can handle and get a reading on a Bronco.
Most of them won't know how to "adjust" anything other than the toe-in, but that's not a big thing. For that, you can find a specialty shop.
And while you're there, you might as well let them adjust the toe-in anyway. You can then use it as a starting point for all the rest of your messing around with alignment.
A key here is to either get a printout, or a full screen-shot of the readings while it's on the rack. That way you have your reference material.
For most EB's, putting the 7 degree bushings with up to a 3.5" lift do not cause any real issues. For most of us...
You will likely feel a vibration in 4-high, but it can be used in 4-low without issue.
I say "in most cases" because there are always exceptions. Many members here had no major pinion angle issues, while others had enough binding to warrant other changes.
So if you don't get a full check first, there's still a good chance that the 7's will be fine.
Looking at your pics again, your front pinion angle seems very reasonable for a 3.5" lift. I'm thinking you'll be fine with 7 degree c-bushings.
But it's still a nice thing to get a pre-bushing caster reading.
If you want to save some initial money on the alignment check (some shops do a quickie check for little or nothing) you can have them just give you a caster readout, and adjust the toe-in yourself.
joshua
I had a set of radius arm poly bushes sitting in my bedroom closet for about 20 yrs. Heated an air conditioned. When I finally mocked up my frame ( never used bushings but 20ys old) they just crumbled into nothing. I replaced with WH angled RUBBER bushing.
J
jdavisjr
Thanks Paul, I will put that first on my list.
Jerry
SLOWnEASY
San Diego, Ca.
I just looked up REV outfitters https://revoutfitters.com/ You might call them first and explain you're working on your Bronco and just want a alignment check with no adjustments to see where you need to focus your attention. Hopefully they work with the community and charge less money for a check than for a full alignment. But they are in business to make money so ........
You might try also checking places like Big O tires or other tire shops that also do alignments. Maybe drive the Bronco down so they can see what you are asking about.
I can see from your pictures from your first posting that you have only two adjustments available, Toe and steering wheel center. I wish mine had the ability to center the wheel.
J
jdavisjr
Thanks you for visiting their web site. I did call them, will take the Bronco over to their shop next week. Will post how it goes.
