Read my pattern.
Rickb1b
First time I’ve built a read end. Standard 9 inch going to 4.56 gears. This is the pattern I got. From what I can find reading, it looks like it might be ok, but I’d sure like to hear another opinion.
grant_71
The pattern itself is good.
looks like your dive side is a little close to the toe of the tooth, might bring your pinion in just a hair to try and center it up.
On the otherhand, I have had much worse patterns and run them with no issues.
Yeller
Rogers County Oklahoma
^^^^ yep this is correct on all counts. I'd also rather be on the toe vs heal, especially if you have a high horsepower engine
STalon89
Thats pretty close. Mine wasnt too far off of that.
bknbronco
North Metro, MN
looks good. Backlash is snug so pattern is towards the toe but some would call that ideal.....once things load up that pattern will move up the tooth and should be perfect. You will be happy with that setup. Once things break in, wear in, and loosen up you will not be dissapointed.
https://www.youtube.com/watch?v=nVb5WRUfM7Y
