houseofdiesel
- Dec 26, 2008
- 253
is that heat exchanger gonna get any airflow where you have it? are you going to put some small fans on it?
is there any way you can mount it in the back instead? i see some of the 03 cobra guys run a large reservoir in the spare tire spot in the trunk so you could throw the res and h/e back there. it would at least save on the underhood heat. just an idea.
It'll get plenty of air flow. I seen another thread where a guy welded vents into his inner fenders. Since I'm going to be building my own all I have to do is get some slotted vent stamped into the metal before I bend it up and weld the seems. Really running out of room. I have both large and small canisters but nowhere to really throw the large one. I do understand that it does run an inline pump, but I just want to keep everything as close as possible and the cab as open as possible for creature comfort.
