Has anyone heard a ringing sound when they turn there steering wheel? I used to here it then it went away and now back or at least I'm paying attention now.
I had a ringing sound when my rear u-joint was going out once when I has a limited slip diff in it...my hypothesis being that turning would exert enough added load to the pinion, thus making the partially failed u-joint to ring the driveshaft like a bell. It was a very distinct sound.
Had this same issue years ago. Way before I learned to work on my own Bronco, so I just took it to a mechanic. He subbed it out to a driveline shop and told me it had some driveshaft issues. Rang like a bell periodically - usually upon acceleration.
I had the aftermarket cover behind the wheel hitting the column sounding like a bell one time.
made a gasket spacer, took care of that. My bearings are probably shot though.%)
Ok I'll start to investigate the pinion and steering column, it was not doing it for a while but now it does it all the time when in turn the steering wheel.......one of many issues
