Sensitive Throttle 77
rmurphy98
I recently bought a 77 Automatic with a very sensitive throttle. It's near impossible to get a smooth start from a dead stop. Any pressure on the peddle causes a slight pause and then a quick lurch forward snapping everyone's heads back. I assume the carburetor /linkage can be adjusted to smooth this out?
Its the original engine and carb. The previous owner had both the carb and engine rebuilt a few years back. Engine runs smooth. Thanks in advance.
77BRONKOTN
Look into better return springs on the carb. That will make the peddle harder to push.
If it is cable, it is not stock.
I know this well. Had the same thing when I first put on the Holley Sniper. But that could be fixed with a simple progressive linkage kit. So the secondaries didn't open off idle.
If you are dealing with a stock 2 barrel there is no secondaries to open later.
it will have to be done in the linkage. Or the cable setup. The simple one is to adjust the ratio. Use a longer arm on the carb linkage. But this will make a longer stroke at the pedal, which can raise the pedal to uncomfortable heights.
Since you have aftermarket cable linkage, it could be installed poorly. Draw a line from the throttle shaft to the pivot ball. How does that compare to the pull of the cable? The closer to parallel they are, the faster the linkage reacts to pedal input. 90° is the slowest but you have to account for the shaft needing to rotate almost 90° for travel.
Since you are doing cable, there are progressive scrolls used in some vehicles. Most notably the early cable throttle LS motors. They start with a large radius and as you open the throttle the scroll moves to a faster short radius.
Rustytruck
on the side of the carb there is a lever with a series of holes that operates the accelerator pump on the carb, that controls the accelerator pump normally Broncos use the hole second to the top. try the upper holes if they are not being used. Check and adjust the idle around 700 rpm in neutral. If you are using an actual cable instead of the peddle rod and bell crank assy eliminating the bell crank maybe the problem too as its no longer the same motion. you need to post some pictures so we can see whats missing.
https://www.carburetor-blog.com/knowledge-base/motorcraft-2100-adjustments/
R
rmurphy98
sorry, there is no "cable", it has the stock rods I must have started drinking early.
Bronco-Brian
Lake Oswego, OR
I've had this exact issue on my Motorcraft 2 barrel stock carb. The issue was sticky throttle plate in the base of the carb. To check, remove the carb, flip it upside down, and view the throttle plates in their venturi (shine light from the bowl side and look for even clearance all around). At idle setting (no choke) the throttle plate contacts the aluminum bore and can stick at very light throttle applications. The fix is to loosen the throttle plate screws and adjust the plate position for even clearance.
