Serpentine conversion, worthwhile?
gr8scott
Hey everyone - from his thread:
Well that's full of suckage!
I am dealing with a "minor" case of that myself. Can't do a lot of things I could do recently, without pain. But at least this time I can still do them. The last time I damaged my rotator cuff, it was mucho majoro.
If you've never done it, you don't want to.
nvrstuk
PNW
That sucks!!! My unsolicited advice for you is do EXACTLY what your surgeon and PT guy says. :)
I was told by so many guys I knew that had some kind of rotator cuff injury and surgery that they went back to work or did some projects before it was 100% healed and tore it up again.
I wanted to go water skiing at the 9month mark and my surgeon ( I called) said not for at least a year. I waited till the next summer and glad I did as I was religious on my PT and I could still feel it pulling due to single ski deep water starts. So.... take it easy as it will feel better after 7-8 months (mine was literally ripped off) and you only want to have surgery on it once. (yeah, PT hurts like hell when the entire shoulder/arm needed reattaching)
Wish ya the best!!
Ol'Blue
Hoping for a speedy recovery for Sanndmann! I was getting ready to PM him for a kit and read the post. I may try and hit the wrecking yard and was looking for additional info on the tech articles and found this post which was also helpful in case you consider pulling and ordering the parts yourself:
Gotta give credit to swmrdrn for the info and redwards69 for the ARP bolt list
https://classicbroncos.com/forums/threads/explore-serp-part-numbers-and-links.285453/#post-3075520
Yesterday I completed installing the explorer serpentine belt front dress on my '67 with the original 289. Thank you to everyone here for the great technical write-ups especially the tech archive (http://classicbroncos.com/tech/explorer-5-0-serpentine-accessory-drive-belt-conversion). One thing that I never found was a complete list of parts, costs, and sources. I thought it might help others if I posted my parts list.
The entire thing went in without issue and it really makes a big difference in the underhood noise level. Now I no longer feel like the accessories are waiting to fail.
If I had one key piece of advice... if you are buying a "complete" explorer front dress from someone be sure you get pictures and a list of included parts. The "complete" setup that I purchased from a member on here turned out to be far from complete. It was missing the discontinued water pump pulley and power steering reservoir, the upper idler pulley, the tensioner, and the timing chain cover was damaged... but it was "complete"... live and learn.
Here is the parts list that I used:
Support Bracket Power Steering & A/C Compressor Ford# F87Z3C511CA Discontinued - Salvage yard only
Support Bracket Alternator Ford# F67Z10A313AA Discontinued - Salvage yard only
A/C Compressor Ford# 4R3Z-19703-A DENSO 4718125 $113 http://www.rockauto.com/en/moreinfo.php?pk=993270&cc=1362462&jsn=8
A/C Compressor Hose Block Vintage Air 045017 $49 https://www.summitracing.com/parts/VTA-045017
Power Steering Pump Ford# F77Z-3A674-DBRM A-1 CARDONE 20277 $30 https://www.rockauto.com/en/moreinfo.php?pk=29871&cc=1354564&jsn=10680
Power Steering Pulley Ford# F77Z 3A733A Dorman 300-009 $15 https://www.rockauto.com/en/moreinfo.php?pk=869978&cc=1354564&jsn=10686
Power Steering Pump Reservoir Ford# F67Z3A697AA N/A $15 Discontinued - Salvage yard only
P/S hose Explorer to 4x4x2 box BC Bronco 48-31410 $79 https://bcbroncos.com/shop/steering...e-hose-stainless-steel-for-early-ford-bronco/
Alternator Ford# 4G7Z10346AARM2 DB Electrical AFD0045 $87 https://www.amazon.com/DB-Electrica...ywords=Alternator&refinements=p_85:2470955011
Alternator Pigtail Wells 224 $9 https://www.amazon.com/WELLS-VEHICL...ywords=Alternator&refinements=p_85:2470955011
Serpentine Belt Ford# F77Z-8620-A GATES K060935 $18 http://www.rockauto.com/en/moreinfo.php?pk=4312&cc=1354564&jsn=10956
AC Comp Clutch Wire Dorman 85152 $8 https://www.amazon.com/gp/product/B000C5CCNG/?tag=classicbroncos-20
Lower Pulley 3 for Hole Balancer BC Bronco $79 https://bcbroncos.com/shop/engine/e...tine-crank-pulley-for-351w-early-ford-bronco/
11 Blade Fan Ford# F87Z-8600-FA MOTORCRAFT YA228 $56 http://www.rockauto.com/en/moreinfo.php?pk=379464&cc=1354564&jsn=4850
Fan Clutch Ford#F67Z8A616NA HAYDEN 2841 $89 http://www.rockauto.com/en/moreinfo.php?pk=1793624&cc=1354564&jsn=5275
Fan Shroud Wild Horses 5001 $185 https://www.wildhorses4x4.com/product/Full_Circle_Aluminum_Radiator_Shroud/Bronco_Aluminum_Radiators
Thermastat Housing Outlet Ford# FOZZ-8592-B FOUR SEASONS 84884 $8 http://www.rockauto.com/en/moreinfo.php?pk=819234&cc=1354564&jsn=7250&jsn=7250
Radiator Lower Crossover Hose BC Bronco $77 https://bcbroncos.com/shop/cooling/...-stock-conversion-pipelower-for-early-bronco/
Water Pump Ford# F87Z-8501-CA Flowkooler 1666 $95 https://www.wildhorses4x4.com/product/FlowKooler-Water-Pump-Explorer-5/EXPLORER5ENGINEPARTS
Water Pump Pulley Ford# F87Z8509AA $50 Discontinued - Salvage yard only
Upper Idler Pulley Ford# 6L2Z-6C348-A GATES 38001 $14 https://www.amazon.com/Gates-38001-...F8&qid=1521572009&sr=1-1&keywords=GATES+38001
Serp Tentioner w/pulley Ford# F65Z-6B209-BA GATES 38161 $32 https://www.amazon.com/Gates-38161-...F8&qid=1521569613&sr=1-1&keywords=GATES+38161
60mm lower idler Pulley (10mm smaller then stock, solves clearance issue) 2002 SAAB 9-5 GATES 36079 $23 http://www.rockauto.com/en/moreinfo.php?pk=1058013&cc=1388460&jsn=2143
Balancer 28oz w/ 3 timing marks Profession Products 80006 $70 http://professional-products.com/ha...y-small-block-ford-28-4-oz-in-harmonic-damper
Timing Chain Cover Ford# F67Z6019AA ATP 103039 $91 https://www.amazon.com/ATP-Automoti...TF8&qid=1521568808&sr=1-2&keywords=F67Z6019AA
Timing Pointer Ford# F1TZ6023A $29 https://lmr.com/item/LRS-6023B/must...NsAGEfDSuT3l1Ha8IsvDmUNT8CizFsp4aAnwAEALw_wcB
ARP Bolts
4 x 5/16-18 Hex Black O.T.V.C Bolt (H3AG3.250-5CL)
2 x 5/16-18X4.00 Hex Bolt (H3AG4.000-5.CL)
1 x 5/16-18X4.250 Hex Bolt (H3AG4.250-5CL)
2 x 5/16-18 Hex O.T.V.C Bolt (H3AG1.250-5CL)
1 x 5/16-18X2.250 Hex Bolt (H3AG2.250-5CL)
2 x 5/16-18X2.00 Hex Bolt (H3AG2.000-5CL)
2 x 5/16-18X1.750 Hex Bolt (H3AG1.750-5CL)
14 x 5/16 ID Chamfer Washers (AGW58)
nvrstuk
PNW
I also appreciate the "complete list". Thanks for taking the time to write that up.
Can you add your list to the actual tech writeup as comments? I have had people comment on a couple of my writeups and I think it's a great thing to do if you have the time!
Ol'Blue
Gotta give credit to swmrdrn for the info and redwards69 for the ARP bolt list. I'll try and add it to the comments of the original tech article. Good idea.
nvrstuk
PNW
I so enjoy the unselfishness of time from so many here on CB. Willing to help out with accurate information w/o all the social media #(%$@ of fb or other sites. :)
Thanks again for your time and help.
V
ARP Bolts
This is amazing! I can’t imagine how many hours of research this list saves. Plus everything I would have gotten wrong. Can’t thank you enough! Time to get shopping.
73azbronco
Ahh, so it's the EB that has destroyed not one, but coming up on two rotator cuffs... Damn, getting ready for second surgery same arm, first fix lasted 10 years. Year I started working on it, bam, pain.
duffymahoney
ARP Bolts
Make this a sticky!
Ol'Blue
Ok I added it to the original tech article, and it looks like admin approved it for all to see now. (y)
* Note that parts availability and cost have likely changed since the original posting of 2018.
ngsd
Are rotator cuff injuries contagious! I just did an MRI and I now have to get it done too. My shop time is limited as well and I have 5 projects all needing attention. This sucks!
Don't know if this info is universal, or false heresy (as opposed to hearsay :) )but I'd heard that the recovery time without surgery was about 1 year. But it's the same amount of recovery time if you do opt for the surgery. Hmm....
And that's almost precisely how long it took for me to get full motion back without surgery and zero pain. Unless I happened to do something stupid that is. In which case it continued to let me know momentarily that I had injured myself previously. Luckily it was limited to just that moment, and once passed things seemed to be back to normal.
Took another six months before even those momentary pangs were gone.
So for me, what was already a no-brainer (no insurance of course), seemed justified and I just let it heat naturally while being careful in my movements.
For now, I'm following the same process. Even though I have insurance now, it's a much smaller issue, pain-wise, than before. But as for being able to do stuff I want/need to do? Just can't do the normal things anymore, that I take for granted.
This is what sucks!
Speedrdr
OLD night owl
Paris, MS
This is what sucks!
Had right shoulder rebuilt in ‘20. Swore I would go to the grave before I had another shoulder surgery…tripped over log chain in my own shop in ‘22 and tore muscle and tendon off the humerus on the left shoulder. At least the rehab didn’t hurt as bad as the right shoulder and ONLY took 3 months to recover. I don’t think I’ll make another rash statement about shoulder surgery. lol
Randy
MarsChariot
Planetary Offroader
Albuquerque, New Mexico
ol'Blue, dude, thanks for doing that. That sort of list is exactly the thing needed for these sorts of things. I can't list the number of times I have tried to duplicate someones suggestions and found that the finding of the necessary parts is a major pain. You should be added as a co-author on our tech article!
Ol'Blue
Glad to help but all I did was found the great posts from swmrdrn for the parts list and redwards69 for the ARP bolt list and copy it over. Thanks to both of them!
Oh and on the shoulder stuff, I swear I'm headed for issues. Every time I climb under that thing, I come out all twisted up and sore.
