Setting up duel tanks
Roushstage3
Pleasanton
I am installing duel tanks on my 66 bronco. I am using the electronic tank selector valve from Wild Horses. I followed the instructions and when I switch it to aux tank, which is empty, the gauge goes to empty, but the bronco keeps running. It is obviously not switching to the second tank.
Any ideas on why that would be happening?
You should be able to test it without disconnecting any of the fuel lines initially. Turn on the key, flip the dash switch to the position that you have new selector valve hooked to, then slide under the rig (not so easy, or fun, when you're tired of course) and disconnect the wire.
You should hear a distinctive click/clunk each time you touch the wire to the stud.
If not, double check that your valve is grounded to the frame, then double check that you actually have 12v coming to the valve.
See what that gets you. Sorry about the hassle, but at least it's not an ignition or alternator! Should be easier to diagnose a bad connection or bad valve.
blubuckaroo
Grease Monkey
Ridgefield WA
The electric valve should only be energized when the aux tank is selected. When the power is off it defaults to the main tank.
R
Roushstage3
Pleasanton
Need some more advice. I have power going to the switch and I hear it clicking, so it should be opening to the aux tank, but it is still running off the main tank. I am stumped. The fuel lines are hooked up as directed.
blubuckaroo
Grease Monkey
Ridgefield WA
Put a meter or test light on the wiring. You should only have voltage when the aux tank is selected. Without voltage, it defaults to the main tank.
And it sounds like you're going to have to pull the lines off and blow air through the ports to see that the valve is functioning properly.
Two things that come to mind are: 1. a defective valve, or: 2. insufficient voltage or current to actually move the solenoid.
Yes, you can have enough to hear a click, but not enough to make it actually move all the way. That seems like the less likely scenario, but with these finicky factory fuel gauge switches always acting up, you can't rule it out either.
The only thing for it now though, is to blow air through the "IN" port with the switch off, then on, to make sure it is changing.
