Sheared the dist. gear pin
ared77
Driving my '66 that has a 5.0 EFI engine and after switching to second gear, engine went dead.:cry:
One of first things I did to troubleshoot was remove distributor cap and see if rotor was able to turn by hand. I did this because I suspected a distributor problem. I could turn it. Got it home and pulled dizzy to find sheared roll pin allowing gear to spin on shaft.
Question - You think that this is just a simple "pin the gear back to dist and drop it back in, at proper timing location" and it will be fixed? I'm thinking yes because if oil pump seized and caused pin shear, I couldn't have turned rotor. What do you think?
Norm
High volume pump?
Cold engine?
What weight oil?
Was the gear replaced ever?
Correct pin used?
B RON CO
Statesville, NC
Hi, X2. I'm starting to wonder why it seems there is a sheared distributor pin every month or so. I could count on 1 hand how many times this happened since I started wrenching in the 70s. Now a lot of guys are running into this. The situation is a gear turning at 1/2 engine speed, turning a distributor shaft, hex shaft, and oil pump. Something must jam pretty significantly to cause the pin to shear. You would think the big load is in the oil pump. Could the clearance in modern oil pumps be so much tighter? Or ? What we used to do was just change the distributor for another used one, but in those days the cars were just daily drivers, logging 100,000 miles or more, and we just said it just let go, so we'll change it. Thoughts?
So ared77, when you turn the rotor, you can feel the oil pump against your effort? I would get a Junk yard or reman distributor. Good luck
ared77
ared77
SteveL, that's what I'm afraid of. I'll get back to it later today and then I should know for sure. But as my question stated, I don't suspect a "seized" oil pump because I wouldn't have been able to turn the rotor (before I pulled it out of engine) if that was the case.
UNLESS the oil pump drive also broke. :(
bronconut73
I've seen pump shafts twisted like a candy cane....but the pin in the dizzy gear didn't snap.
That was two different Mustangs. Both did it while street racing.
A '67 with a transplanted built 351W.
A '66 with a hot 289.
Crush
Greenbottom, WV
Mine sheared also shortly after getting it running. I have a roller 351 and am running duraspark and carb. When i changed dizzy gears to match the cam i had a hard time getting the pin all the way in. I think the gear was alittle crooked on the shaft and caused the pin to shear. Reason being the top of the dizzy rocked a little when it was running also when i put the new pin it i lined up the holes and it went right in this time and when i did deanos the dizzy gear was a little crooked and i made sure the holes lined up this time and it went right in. So my question is, had you changed the dizzy gear? If so maybe the gear was a little crooked. Idk but just a thought. I have not a problem since
ared77
ared77
No, I hadn't done anything different to it, just drive it since I bought it.
Anyway I only had about a hour to mess with it today, but I got it running again! ;D
Just replaced the sheared pin, reinstalled distributor, and started it. No time today for anything else, still strapped to trailer. Soon I'll change oil/filter, adjust timing, etc. Hopefully that's all it was.
B RON CO
Statesville, NC
Hi, the gear is a tight fit on the shaft. If your gear is loose on the shaft that could cause trouble. If the gear is loose it could slowly damage the roll pin. Good luck
Cortez
Mine sheared last month and had clearly done so by loosening a little over time...the hole was out of round on the shaft. Other than that, no oil pump issue. If your dizzy is old you may notice the hole got some slop which could lead to shearing as in my case.
ared77
ared77
My gear didn't rock on the dist. shaft...but it does slide on and off easy. It was not a "press fit" situation by any means.
ared77
ared77
Update, after repairing the sheared pin, changing oil (Brad Penn) and filter, and setting the timing, I've now been driving it again. So far so good. It appears I got lucky and it was just the pin. Still makes me a little nervous, thinking something else caused the shear. %)
First pin I ever sheared was on a '67 Buick 430 Wildcat at about 110k miles.
Never did figure out what did it. Replaced it and drove it an additional 140k miles or so and never had the issue crop back up.
Never sheared a pin on any of our Corvairs with high-volume pumps, but knew the possibility existed. Sheared a few more on various small block Chevy's, but it was totally haphazard.
Doesn't mean you should not look for root causes when it happens. Just saying it can be lots of things that won't rear their ugly heads again. Such as a defective pin for instance. Or one damaged during the initial installation (assuming that's possible?) and stuff like that.
DJs74
Norm
Not trying to be a kill-joy and glad you got the pin fixed and it's running again... but the lingering fact is that something caused the pin to shear. Could've been a bad pin I guess but a bad pin should've failed soon after it was installed.
Is this a new build / old build or unknown age build?
What camshaft? Was there a distributor gear change made to match the camshaft material by any chance?
The gear location on the distributor shaft (dimension from base or distributor to bottom of gear) is critical. When the engine is running, the direction of revolution between the cam gear and distributor gear causes the distributor gear to pull downwards toward the oil pump (when installed at the proper dimension, the gear bottoms out on the block boss). If the gear is installed short, the natural occurrence for travel could be more than the pin can take, it bends and eventually shears. If the gear is installed too far down, installing it and forcing it down with the hold down clamp would push the gear toward the intake... also causing stress on the pin and possibly an eventual sheared pin.
High RPMs usually accelerates (no pun intended) this situation.
This may not apply at all to your situation but the dimension is easy enough to check by simply pulling the distributor out and measuring it.
DJs
ared77
ared77
Base of distributor meaning 'where it contacts block, up by hold down clamp'?
Measurement from there to the bottom of the gear, right?
pcf_mark
I'm not sure what you are trying to measure but a quick, easy and accurate way is to install the distributor without a gasket it should sit flush on the block. If it sticks up that is a problem and when you tighten the clamp you are forcing the distributor into the oil pump making it hard to turn.
DJs74
Yes, the surface of the distributor base that sits flush on the block to the bottom of the gear
And like Rustytruck states, always use a new roll pin. I personally prefer the spiral wound type and I usually bump up the diameter of my pins from Ø1/8" to Ø3/16"
Also, if I run into a situation where I have to re-drill the distributor shaft, I rotate and re-drill 90° from the original hole
Here is a link that talks about the procedure and shows the measurement
https://performanceparts.ford.com/download/pdfs/DistributorGearInstallation.pdf
DJs74
ared77
ared77
DJs74, good info page, thanks!
Rustytruck, new pin installed.
