NY-Bronco
Resident Dipstick
Is there a point/need for the spacer between the throttlebody and the upper manifold? Do I need that?
How is it recommended to plug the holes?
On the ones I'm familiar with, there is a single hole in the center of the lower manifold, in-between the intake runners. I've heard that you can thread a pipe-plug down into it and either use sealer, or weld it in. I would think that if it's sized right and you pre-thread the hole, it should seal pretty well.
Otherwise you can just leave it open and use the block-off plate that fits between the throttle-body and the upper plenum.
The problem I am having is the torx are shearing off in the bolt. I have to try and dig it out to go at it again....
if you are running a egr eliminatior plate there is no need to block the passage in the intake? Is this correct? or do you have to block the passage and use the plate
