starting issue. won’t turn over
7T2
hey guys new to the forum and to broncos. and i need some help. i recently bought a 72 bronco with a 302 which has been awesome. we had a cold snap a month or so ago and it got down to 17° which is cold for Georgia lol. reason i say that is cause i tried to crank the bronco up during that time to get some antifreeze flowing. it did not crank.(this is where i think the damage happened, i tried to crank it for way too long stupidly)
weeks later once it warmed up i tried to crank it again. nothing.
i thought it was the battery as it was dead and wouldn’t hold a charge. so i replaced it. with the new battery installed i tried to crank and nothing happened except for the Electric fan coming on. it would not turn over.
i then replaced the starter soenoid. same issue. won’t turn over. only e fan coming on.
i then replaced the Starter today. same issue. won’t turn over and only the electric fan will come on.
what can i check next?
it has MSD 6AL ignition control.
MSD blaster 2 coil.
MSD distributor.
7T2
i also have replaced the hot side cable and the cable going from the solenoid to starter.
spap
Can you turn it over by hand with a socket on the crank pulley.
Hey 7T2, welcome. Sorry to hear you're having trouble turning over!;D
But to clarify, when it's got the issue are you even getting a click out of the starter relay/solenoid, or nothing at all?
Other than the cooling fan, does everything else in the cabin work? Heater, turn signals, flashers, etc?
Good thing to have new battery cables (you should consider changing the ground cable at the same time, though it's not strictly "necessary" until it is), but new starter relays are very troublesome these days.
There are some easy tests though, before you have to spend any more money on parts that might not be needed. The good news is that you may now have some good spare parts!
Anyway, let us know what it's doing exactly. And even though it's a '72, is this an automatic or manual transmission?
What month was it built in? If very late in '72 (you have a "P" or a "Q" in your VIN? As in, U15GLPxxxxxx?
Just thinking out loud here, but if Ford made an early running change to the wiring harness, you may have a '73 harness with the Neutral Safety Switch plug behind the engine. Would have 2 Black w/red wires and 2 Red w/blue wires. With a manual trans, there is a jumper loop in the second half of the connector that takes the place of the automatic trans' safety switch. This loop often deteriorates and causes a "no clicky, no starty" situation.
But if you're still getting the relay click, this is not your issue.
Worth looking for anyway though.
Good luck.
B RON CO
Statesville, NC
Hi, 1st, double check all the cable connections, and remove and clean any you never touched. Make sure the negative cable goes to the engine block, body and make sure the solenoid has a good ground.
Next, check the small wire on the solenoid at the S terminal. This is the small wire under the large wire which comes from the battery. Pull the small wire off the solenoid and use a test light or multimeter. This little wire should be hot when a helper turns the key to start, and go off when the key goes to the run position. It tells the starter to turn.
The other thing mechanics can do is jump the S post to the positive battery cable end with a remote starter switch, or a heavy screwdriver. When you jump the solenoid make sure you are in neutral or park, because the Bronco will roll if in gear, and can start if the key is on. Try that and post back what happens.
Good luck
7T2
thank y’all all for replying.
spap yes i can
dirtdonk it is a P code, so i’m guessing early model 72? it is a manual transmission that has been relocated to the floor.
B Ron Co i grabbed my volt meter and everything seemed to check out.
so i bypassed the solenoid by having a helper hold a wire to both sides of the solenoid, it cranked right up!
so i guess i have a bad solenoid from the factory?
also when it fired up it sprang a leak from where the heater coil hoses once connected(p.o. removed the heater for some reason) luckily that seems to be a easy fix. drain the antifreeze out, replace the rubber cap(which is very dry rotted it looks like, which i think caused the leak), and refill with antifreeze.
Nope. As far as we can tell, that's the very last of the '72's before they became '73's sometime later than normal that year. I forget if it was Sept. or Oct of '72 for the transition, but yours was near the end.
When you have time, pop on over to Viperwolf1's thread titled "Mind Your P's and Q's" and list your stuff.
We like to know the month is was built (if you have your door decal on the driver's side still, it will list the month of manufacture), whether you have the dash light bars, dual-port return line on the fuel selector valve under the floor and a piece up at the carburetor, and other stuff like that.
It's a pretty cool bit of data and we're trying to get all '72 and '73 owners here to join in the discussion.
Because it's a P and not a Q, you probably don't have that 4-wire connector I was talking about. But it would not hurt to make sure.
So i guess i have a bad solenoid from the factory?
One of hundreds! The Ford starter relay is nowadays (for us here at least) one of the most widely purchased, failed new parts out there. Seems like almost everyone that has replaced one has their story to tell.
Big pain is what it is. You almost have to buy three so you don't have to go back to the store two more times if yours is bad out of the box.
p.o. removed the heater for some reason.
Who knows what goes on in their minds.%) But then, someday we'll be those dreaded PO's too!
Could have had a leak and not felt like replacing the heater core. Could have lived in Florida and wanted the simplicity. But whatever the reason, those caps don't last near as long as a hose does. So if you don't mind the clutter, but still don't want a heater, you can loop a piece of heater hose between the two ports on the engine.
This way it will still block leaks, but likely last a lot longer.
Good luck
B RON CO
Statesville, NC
Hi, glad you're getting somewhere. I would get the new solenoid from Napa, and get the best one if you have a choice. They seem to try and keep the quality of the parts up.
It sounds like you have a heater core in your future. Who knows, you can save up for a Vintage air ac and heater unit.
If you don't have a Chilton's manual put it on the list.
Good luck
spap
Welcome to the fun it doesn’t get that cold here so wasn’t sure how that would effect things
El Kabong
Driving stuff Henry built
spap yes i can
Try jumping the solenoid from the large hot post to the small "S" post. If it cranks like that the solenoid is not the issue. If it cranks while jumped from hot to "S" then test the small wire that connects to the "S" post for 12v when you turn the key to start. No juice there indicates a problem in the small circuit that includes the ignition switch.
If it does not crank jumped to the "S" post, but does when jumped large post to large post, the solenoid or its ground is bad.
7T2
well after trying a different solenoid and it still not working, I came back here and carefully re-read everyone's posts.
so then I ran a wire from the other small post on the solenoid to the negative post on the battery and sure enough it fired up.
which makes me wonder how the original solenoid worked? I guess it grounded through the body of the solenoid? where as this new one does not?
and thanks to everyone who has helped me with this. this is the first forum I have joined where the members are not assholes to the dumb newbie.
Damn newbies!;)
Haha! Yep, they do ground through the body, but there may be some that don't. However, if it's supposedly a direct replacement, it should ground through the body.
Yours is stranger still though. I don't remember anyone ever trying to ground the small post. Is this the one on the right side, possibly marked "I" near it? Do you now have an extra wire and connector somewhere?
Strange.
Another question though (that may already have been asked?) is how well is your body grounded now? Is the negative side of the battery also connected to the body as well as the engine? It's supposed to be for this reason. And it's how Ford did it originally.
What happens a lot is when a new negative battery cable is installed the body ground is often overlooked and left out.
How is yours routed? Just to the engine, or still to the body?
I mean, hey, as long as it works, right? But it's still a mystery as to why yours is requiring that. Sounds like a funky new starter relay to me. But like you said, it works.
Congrats!
bronkenn
Bronco Guy
Southeast Ohio
Oh and welcome to the forum.:)
