Steering Help
editgod@hotmail
LA
Hi,
Can anyone recommend who makes the best Adjustable trac bar and Drag link to kit to help centre my front axle and give me equal left and right turning circle (I currently have no left). I have a 73 Bronco with a 4" lift, Wild Horses Power Steering, Toms Disc Brakes and a Wild Horses drop trac bar bracket.
Thanks for your help, Guy
Tito
CB Fire Starter
Bakersfield, CA
I have the WH adjustable track bar, top notch and easy install.
May as well get the drag from them too. Most of my stuff comes from WH and Toms.
fordtrucks4ever
DFW
If you have no left, something might not be bolted on correctly. Any chance the pitman arm is not indexed to the center steer of box?
E
editgod@hotmail
LA
Looked at that, the position of my Pitman arm is'nt adjustable as the arm will only fit onto the Steering box in one position (not sure what the technical term is) so thus started thinking about looking at a new drag link.
E
editgod@hotmail
LA
Yeah thanks I had seen them but didn't know if anyone could recommend a particular one as they are so many about.
How little is "no left"? I'm assuming it does turn left still, just not as much as right? A 4" lift and a drop bracket shouldn't have effected the turning radius as much as it sounds. Maybe a tiny bit, but a lot? Maybe, but still sounds strange.
Good luck.
eds66bronco
Essex, Vermont
the best way to do this is to disconnect the drag link and turn wheel full left and then count number of turns to go full right. should fall between 3.5 to 4.5 turns depending how the box is geared. now go back to center by dividing the first number in half. get out and look to see if the pitman arm is pointing straight back (parallel to frame rail). if not, this will tell you if your pitman arm is indexed correctly and if the drag link is too long or too short. also check to make sure the knuckle is hitting the stop bolt on each side.
i also like to check that the axle is centered under the truck. compare the distance from the frame to a spot on the axle like the radius arm cap on each side or you can drop a plumb from the wheel well opening and measure to the sidewall of the tire if your body/fenders are straight.
E
editgod@hotmail
LA
Thanks ed, I only have 1 turn to the left at the moment and 2 to the right (with drag connected) and my wheels are definatley off centred. Maybe I will buy the adjustable track bar before I get the adjustable drag link.
Thanks for your help.
Guy
You might end up needing both anyway, but definitely start by getting the axle back in the center.
If you're using an aftermarket pitman arm, it's possible that it's not indexed the same as the original.
It's not a big offset, but combined with other mis-alignments, would just add to your grief.
You can get things right again by filing a groove in the keyed spline and re-aligning the arm to bring it back into a better alignment with the draglink.
This way you can make sure your box is centered first, like Ed was saying, then match up everything else to it.
You might still have to use an adjustable draglink to make it perfect, but this gives you some more adjustment range.
