- Dec 29, 2010
- 1,774
2 separate problems or are they connected? Lately I can barely get out of the driveway w/o blowing a fuse. The p.o. Wired the electric fuel pump into the same circuit as the turn signals.
So I pulled the pump off that circuit then turned the turn signals on & aimed my temp gun at the fuse inside the glove box. Sure enough the fuse heated up to 160 F before I shut the turn signal off. I tested left & right, same results.
I also noticed my break lights would not light up!? I jumped the switch that plugs into the stop switch & the breaks lit up. Ordered a new stop switch & moved on.
Went to test the hazards & they don't work now?
Here's what I'm wondering, is the little box that the hazard switch goes into capable of shorting out or over heating the break stop switch & the turn signals?
Could that hazard box with the 6 wires attached to the top be causing all of my electrical gremlins?
