While you're checking your gauge accuracy (what do the oil pressure and fuel gauges read, compared to reality?) also check your ignition timing.
Running too little timing can encourage an engine to run hot.
Does it matter what color of fluid I put in it?
Usually, yes it matters a lot.
Generally speaking our old Fords take the green stuff. But whatever is in there now, you also usually do NOT want to mix different colors together. Even though there are those that claim to be universal and will mix with any type (and that's a good thing) when I am buying new and don't have to settle for one or the other, I just use good old green.
What color is it now? Is it just water, or is it a color with anti-freeze already?
If it's just water I would leave it for now, since water alone not only cools better, but if you have to open the system up to fix anything, it's less messy to just change water!
You just don't want to leave it that way for the long term.
What temp stat should I put in?
At least a 180, but I typically use whatever Ford had in there originally. I like 195's for the V8's but don't know if going that high has the same benefits for the six.
If that doesn't help I'll flush the radiator out.
Good plan. But those last two items are all the more reason to wait for the anti-freeze until you've got it all dialed in.
Not only does it save you money to not waste brand new anti-freeze, but definitely makes for easier cleanup.
And most flushes ask you to drain the coolant and add just water before flushing anyway.
Good luck.
