Temp Sender Replacement
BroncoTwin
Ponte Vedra, FL
First time posting here, so thanks in advance for any helpful tips. I recently bought a 1968 Bronco with the stock 289 engine and noticed the the Temp and oil pressure gauges were not working. Searched the forum and found out how to rule out the actual gauge as the problem. I replaced the oil pressure sender and it worked. However, when I replaced the Temp sender, the gauge still did not work. Any suggestions? Thanks.
Mikesimp70
I taped mine and it didnt work. Removed tape and it allowed the circuit to complete.
BroncoTwin
BroncoTwin
Ponte Vedra, FL
Thank you for the tip. I just removed the tape and still nothing...? I grounded the temp sender wire again to make sure the gauge was functional and the needle moved freely without issues.
Jfryjfry
Sounds like the sensor is bad. You can still seal the threads, but verify that you have a closed circuit/connection between the sensor and ground. Sometimes an additional ground wire is needed for the sensor to both seal and ground properly.
JSBX
Could be the wire from the sender to the gauge is broke or corroded. The first thing I would check is the connector at the sending unit then connector at gauge or run a jumper wire.
bronco loco
It never ends
Long Island New York
This indicates that the gauge is working and there is a problem with the sensor, unlikely that there is a problem with the wiring because when grounded the needle swept freely. I had exactly the same issue 3 weeks ago.
What sensor did you get? Although there was only a gauge offered in the Bronco the parts books usually have two different sensors. One for "with light" that usually costs less, and another for "with gauge" that costs more. If you got a "with light" sensor it will do as you are experiencing. Absolutely nothing, until it gets hot, where it should ground out and turn on a light.
Nicks501
Curious to hear if you have had any luck yet. I have been chasing this gremlin also. My other gauges seem to be working. Have tried 2 new temp sensors (1 motorcraft, 1 from Napa) same result. Reads very low. Teflon paste was used on the 3 sensors. I can unhook the temp wire and ground it, the temperature gauge will max out (so should eliminate wiring problem). I have tried grounding the sensor thinking maybe the aluminum manifold is somehow not grounding no change there either. I guess my next step is a new temp gauge or just not worry about it.
Could be a bad gauge. swap the signal wire with another working gauge. The needle swing should be correct. I think it is temp and fuel gauge are the same except for a face plate. I remember swapping faceplates to get 2 gas gauges at once (one for each tank)
garberz
Bronco Influencer
Conejo Valley, Ca.
Yup, water temp, fuel, and oil pressure, all the same ohm range. Just different faceplates. Amps is a different type of gauge.
Mark
If there are two people available, have someone watch the gauge while you push on the connector (still connected to the sender) to see if anything changes.
The biggest issue these had when they were only 10 to 20 years old, and parts were more reliable from the parts stores, was the 90° push-on connectors. They'd get a little loose and not give a good reading.
Some time spent gently crimping them down with some needle-nose pliers would usually fix it for another five or six years.
Worth a quick check anyway.
