That is not a good spot.
If you look at waterflow through an engine it makes sense why not. To start with cooling is done as a pair of 4-cylinder engines, not as a whole engine at once. As the waterpump pushes cool water into the engine there is a port off the waterpump for the left side of the engine and one for the right side. The are completely separate all the way up until the intake manifold where they are merged back together just before the thermostat.
So the water is pushed into the block. It flows past the cylinders with only a few very small passages up into the head for spot cooling. Once it reaches the back of the block most of the water turns up and goes into the head. Now it flows from the back of the engine to the front through the head. The head is the hottest part of the engine and does most of the cooling. At the front of the heads the water from both sides is joined back together and goes through the thermostat and radiator to start all over again.
Putting the temp sender at the back of the head as you have it shows the water temperature after going through the block, but not after picking up the majority of the heat in the heads. So a poor flowing cooling system (stuck thermostat) will be boiling water in the heads, but the cooler water in the block is what the sender will be looking at telling you all is well. It will be reading lower then actual temperature. IF it is running hot back there you know you have an airflow issue as the water is leaving the radiator still hot.
