Temp Sender Help - Calling Viperwolf
Ol'Blue
Temp gauge has always read too low, never over 170*
Got a laser temp guage to check and pointed at the sending unit I get about 190*
Read through several threads on the topic including the one below and decided to go with the NAPA TS6153.
Now gauge is reading 225* and laser thermometer is 190* at the sending unit.
Should I trust the laser thermometer and based on the below comment from Viperwolf in the thread go with the TS6628 insted?
"They are different the 6153 has 15.2-19 Ohms Resistance At 220 Deg F
The 6628 has 22.7-25.5 Ohms Resistance At 220 Deg F"
http://classicbroncos.com/forums/showthread.php?t=230068&highlight=ts6153
Viperwolf1
electron whisperer
Laser thermometers are pretty accurate. 40 year old gauges and wiring may not be. You should check the accuracy of the oil pressure and fuel gauges also to see if the instrument voltage regulator may be the problem. 10 ohms of resistance to a good ground should drive all 3 of those gauges to there max. If the problem is just isolated to the temp gauge you should check the wire resistance. It's also possible to adjust the gauge itself though I don't recommend it.
Ol'Blue
Ol'Blue
Not much with electrical but I guess I will learn.
The gas gauge seems right. Was at about 1/3 on the rear tank and it took 9 gallons.
Oil pressure creaps up slowly to 40 psi and stays there pretty much all the time.
demesauce
Shaver Lake, CA
First off your laser thermometer is trying to get the temp of the brass sender unit, which is gonna be slightly different from what the sender itself is reading. Next, where have you installed the sender? Is it in the intake manifold? I have seen some people install it at the water neck and others have it in the block somewhere.
JSmall
I have the same issue. When my cluster was refurbished the temp gauge was replaced. Since then, 160-170 is what mine reads. I didn't realize I had options to fix.
Ol'Blue
Ol'Blue
Did some more reading on here and sounds like the TS6153 is for the earlier models and the TS6628 is for the later model. Also checked parts application on NAPA website and seams to confirm this, so will try the 6628 and see if I get a more accurate reading.
demesauce, the sender is in the intake manifold. Thanks for the input.
Nellybell
I have a '71 and I run the BWD WT386. Seems to be right on with the after market gauge I have.
Good luck,
Ted
Ol'Blue
Ol'Blue
Thanks Nellybell !! I installed the BW WT386 and it seems to be the right one. Tested it out last night and its matching what Im getting with the laser temp gauge at various temps.
Did some more checking on the different part numbers. Looks like they changed the sensors in 1970.
Napa
67-69 Echlin TS6153
70-77 Echlin TS6628
6153 has 15.2-19 Ohms Resistance At 220 Deg F and 6628 has 22.7-25.5 Ohms Resistance At 220 Deg F
O'riellys
67-69 Borg Warner WT324
70-77 BW WT386
JSmall I see you have a 76 maybe when your cluster was rebuilt they used parts from a 67-69??
Not sure that would have anything to do with it......
