Tricky Dick
- Jul 13, 2023
- 337
Or in my case a router.Gotta love a good lathe
I saw a few videos on youtube and it didn't look hard. And it wasn't, just very slow going, but I also used a wood bit.Wish I had seen this before now. Never thought about using a router. I’ve done two Dodge rims using an angle grinder and a die grinder. Ain’t pretty, but it clears the hub. Thinking I’ll get a metal cutting bit and work on the other two.
Randy
How did you set up your guide?I saw a few videos on youtube and it didn't look hard. And it wasn't, just very slow going, but I also used a wood bit.
I used a 3/4" bearing on a 1/2" bit and guided off the original bore. The original was 93mm so it it made a hole about 87-88mm.How did you set up your guide?
If I had that kind of hook up I'd be all over it. But this only took a couple hours to do 5 so not bad. I'm thinking about going over them again and putting a stepped lip to click center caps into, if I can find center caps the right size that is. I think worst case I can use 3.25" trailer wheel push through caps.Glad I have a machinist that will do this for $25 Mark the one armed machinist, he ripped his arm off on a lathe years ago and was back at work two weeks after doing it!
Are you measuring the top plate u-bolt holes inside to inside? Or center to center?I have a nice set of antiwrap perches and heavy duty top plates on hand but they are 2.5" wide instead of 2.25".
I think a lot of people have run it that way over the years. But I’d rather see the inside of the U-bolt pushed up almost against the springs.I've seen a couple instance where people say it's fine but I'd like some reassurance...
Inside to inside. I know they're for 2.5" springs because I bought them for another project once upon a time.Are you measuring the top plate u-bolt holes inside to inside? Or center to center?
I assume inside to inside.
I'm thinking 3" so I can run 5.5" springs with only 2.5" lift. I know 2.5+1 is kind of tight for 37s though.Moving the coil buckets up does so much for performance, allows the weight to hang down between them like a hammock. Best way I can explain it is compare it to sitting on a ball, not very stable and your core is getting a work out, it just wants to roll. Now sit on a swing, it’s stable and not falling over. I’ve also compared it to picking up a baby and holding them out at arms length. Pick them up by the hips and they are floppy and look around like a wobbly crazy cat looking for the escape door. Pick them up by the rib cage under their arms, they are now stable and giving you a stare down.
Just means you need to cut more sheet metal, 37’s fit with 0+0I'm thinking 3" so I can run 5.5" springs with only 2.5" lift. I know 2.5+1 is kind of tight for 37s though.
I can do that!Just means you need to cut more sheet metal
