Here's some measurements for now , bill of materials , 1/4"x 1 1/2"x 1 1/2" angle x 7 5/8 " 1"OD x 11/16" ID tube , 2 @3/4" and 1 @ 5 3/8" . I used a piece of 5/8" 4140 solid round bar for the pin , it measures 10 1/8" in length with one end machined as a standard Reese receiver pin and a 3/4 " nut welded on the other end as a stop . A guy could anneal a Reese pin and weld a piece onto it . My pedals measured 5 3/4" Cl. to Cl. and they were .340 thick, (yours may vary) so I used a 3/8 " drill to punch a series of holes in one leg of the angle from the web to the edge and finished it off with a cut off wheel . These slots measured 1 1/4"X 3/8" and slip over the pedals from the rear . I welded the tubes to the front of the slotted leg so the pin passes over the rubber pad side of the pedal. I did one other thing afterward , I welded a 1/4" x 2" x 3 3/4" to the back of the unslotted leg at the center of the angle to keep the pedals from being depressed , you may have to verify your measurement . My pin has to slide in from the trans. hump toward the kick panel and the lock is between the clutch and E- brake , hope this helps as my finger is tired ! I think one look at this "Iron Maiden" would stop most joy riders though.
