Theft Deterrent
Fathom
Los Angeles
greasypigeon
Fort Bliss, Tx
Me
I just turn off my gas tanks, So if someone does nab it they won't go very far. About a few hundred feet, then the lines run out of gas and it dies. And they just ditch it.
JokerOfDeception
Whittier friggin cal
I am in socal..... and have been working under the hood of her alot recently since ive put the bikini top on it, and in all honesty i have seen some peculiar cars go down my street ( a dead end) for no reason and creep by my house. It worries me, so i climb it up halfway onto the woodpile on the side of my house, switch the tank over to the non existant aux tank, let it run for a minute and then shut it off myself before it dies. The neighbors think im nuts..... but iiiii dont :)
j.r.nice
Fathom said:
Bart posted this in another thread
http://www.brakelock.com/
Warning I'm just quoting Fathom because of the picture. This is not an attack!! ;D
I dont think I would be interested in using the brake lock.
First, in order for security products to be useful and used they have to be somewhat convenient (passive compared to active). At first it doesnt matter but then.......
That said, I cant imagine installing that under the dash. It's not just the pretty lock.......your piping brake fluid into your interior. Just the effort alone to mount it and run nice steel lines to it would be a deterrent to putting it there. Then what if it leaks?
So, you (generic) opt for a different location........hey, how about under the driver's side fender or fenderwell. Again, in the battle between brake fluid and paint.....brake fluid always wins. Ok then inside the fenderwell (where all your mud. dirt, snow ends up. Locks dont like debris. But you put it there anyway. A cunning thief is going to watch you and your truck before he makes his pass. Obviously, no matter where you put it, you have to unlock it. He can/will see you. Let's say he only watches you twice. He now knows there is something under there. If he's anygood he will know what it is. He will know all he has to do is cut the lines and your security is gone.
No he cant safely drive it away, but why would he anyway. Load it on a trailer and boggie. Yes, it will keep the pesky amateurs away. But I dont worry about them anyway. A fake flashing LED and club will keep them away.
I guess diasabling your brakes is ok for a security measure but I just dont like the idea of messing with the hydraulic aspect to accomplish that.
astark
Bronco God
I just checked the link and it's working for me. You may need Quicktime and Java enabled but I don't know for sure. The video shows the flame thrower in action and a guy getting burned up.
j.r.nice
Ok, I'll try that. Maybe that's why some other stuff doesnt play!
I think my Norton disabled some of that stuff.
supermottl
Indian Harbour Bch,
I don't really worry so much about theft around me. I'm like the only EB owner for miles, and those others on LI who have EBs all have different colors (I think), so mine would stick out like a sore thumb and anyone would know it's mine. Besides, there are tons of small things you could do to prevent amatuers from taking yer rig:
-Kill switch (for those who have the RF wiring kit)
-Swipe the coil wire
-install keyed ignition switch (Mine had pushbutton start before)
-gas tank switch
-twin sticks in N
yada yada
I mean, if someone if gonna take your rig, they gonna take it with a tow truck or similar... that just sucks
mtkawboy
Billings Mt
I bought one of those 5 ft contractor Master Lock coated cables to lock the hood down. It attaches on the right side of the hood with a quick disconnect. You have to wrap it thru the frame holes a few times then lock it with a big lock. I did it not because of theft but because the PO had someone put 2 ball bearings on the secondary thottle pates and destroyed a high dollar motor I had built for him. I bought it from him with a stocker rebuilt 302 in it. I just worry that they might not know he doesnt own it anymore. I also have a hidden kill switch. Like you say if they have a wrecker its history but you can stop some vandelism. The ball bearings totally destroyed the good motor by the time he got it shut down from speed passing a car opening the secondaries.
Fathom
Los Angeles
I was just providing info, I would never use it either. For some of the same reasons you stated.
How it works is (I think): Mash down on the break and turn the key. This locks the breaks on by holding the line pressure. So it needs to be were you can do both. Under the hood or fender won't.
If you turn the key W/O mashing the break, you now disabled your breaks. BIG safety issue!
If I would mount it, I would put it were the aux gas valve is usually (under the driver's seat. Maybe, only do it to the rear tires ?:? So, you can still stop if you accidently disable the rears....
Anyway, I saw someone asked about a key and I found the old post....
So no offense taken and thank you for your observations! They got me thinking...
Fathom
mtkawboy
Billings Mt
I actually had a 9th grade science teacher that wired his car up to 120 volt house current because of people stealing gas. Unfortunately he ran out to it in the rain forgetting about it and killed himself. True story, 46 years ago. I think he only intended to shock someone but didnt figure in the rain.
