Tie Rod Over
flousberg
I am replacing my front axle bushings. While I have the axle out, would like to do TRO. I have Dana 44 with F150 knuckles. I currently run stock draglink under with bushings, no track bar drop or riser, drop pitman arm. 3.5” lift. No bump steer. I will need to ream and add bushings I know this. I assume I will go back to stick Pittman arm. I think that might get everything parallel again but worried about drag link hitting Trac bar or stud.
flousberg
flousberg
I have 4” back spacing with 1.5” spacers. Not an issue. Real question is on the Trac bar and vendors.
You’ll either have to wait for someone with the F150 knuckles (and TRO) to chime in, or kind of figure it in yourself with tape measure and eyeball.
But in most instances, you are going to run into interference with the lower bolt with a tierod-over swap.
Multiple solutions have been tried over the years. All successful so far.
Cut the bolt down and use a low profile lock nut, or use a track bar riser to get the bolt completely out of the way, are the two most common.
The riser can actually come in handy with parallelism too, depending upon what linkage you decide on.
Where are you on that aspect?
What size tires, and do you plan to go off road with the Bronco?
Yeller
Rogers County Oklahoma
TRO with a track bar riser and a stock pitman arm will give you the best driving experience on a lifted bronco. As for the riser Wild Horses would be my go to. You shouldn't have any interference issues, other than maybe needing to trim the bracket to not hit the frame at full compression, or lower the bump stop to accommodate. Sometimes we see draglink interference with the end of the stud where the drag link goes through the tie rod, in every case of that the tie rod is not clocked correctly the head of the drag link should be pointed at the bottom of the radiator, not parallel to the ground. If it still had contact the info from DirtDonk is spot on.
flousberg
flousberg
I have 35s, 3.5” lift. 2” BL for my 351EFI. I have ran this for 24 years. Not heavy rock crawling but have the capability. Arbs front and rear. Just hate body damage.
flousberg
flousberg
I need to get tie rod and draglink and either use 1 ton ends or heims. Any recommendation on vendor?
Yeller
WH has several options, all of which I believe would meet your needs. WH steering linkage upgrades
One of my personal requirements, is the drag link and tie rod connection points must be in factory locations. altering those potentially increases the odds of bump steer. I rarely put hiem steering on anything anymore, it is almost always tapered rod ends and factory style components. There are some very nice upgraded units available now that are a nice improvement in strength without the added complication of full custom parts.
Apogee
Tangent, OR
X2 on the WH F150 tie-rod option and drag link to match, paired with a track bar riser on the axle and factory pitman arm on the box. That should give you the best outcome with the least cost/work. I'm doing the full custom route on mine with Chevy TRE's, bungs, custom track bar + mount, full width HP D44, etc, so not super easy or cheap so far.
flousberg
flousberg
So from WH
That look correct? $519.
Yeller
Does to me. If you call them they can coach you as well. You’ll not find better informed, helpful group of customer service folks. I buy parts from them to use in non-bronco applications just for their customer service, that and the Creels (owners) are top notch great folks.
kevscj5
Colorado
Your list from WH looks complete to me. They are some good people there who will help, indeed.
I did a similar upgrade over last winter. I have a '77 F150 high pinon front 44.
Used the following...
-WH track bar riser bracket.
-James Duff custom HD adjustable Track Bar with a bend in it to help clear the oil pan at full stuff.
-Extreme Custom Fab heavy duty Tie Rod and Drag Link with 1-ton TREs.
-Tie-Rod over by reaming and Extreme Custom Fab bushings for 1-ton TREs.
-Reamed the Pitman Arm hole as well to accept the 1-ton TRE on the drag link.
Turned out pretty nice and the 2 bars are dang close to parallel.
One interference issue I encountered was between the bigger TRE at the Pitman Arm and the Tie Rod, when the driver side is stuffed up and the two parts pass each other.
I purchased a different TRE from Moog which had a slightly smaller body and I ground a small flat spot onto the interfering side of the TRE body so that it clears now. I pulled back the front axle a hair too by tightening down the radius arm Heims by a turn.
