Timing covers...
eBronc
Austin, Texas
Anybody know if Ford ever produced a timing cover for Windsors that accomodated both a reverse rotation water pump AND had the mechanical fuel pump port?
The vast majority of Windsor timing covers are for the older, standard rotation pumps and have the fuel pump mounting provision, but it looks like when the 302's became 5.0 HO's and went with the serpentine belt and reverse rotation water pump, (which has a slightly different mounting bolt pattern and the ports are angled the other direction) they went to EFI at the same time and no longer have provisons for mounting a mechanical fuel pump on the timing cover.
I'm just about done with my 351W rebuild, but ran into a snag when I realized that the timing cover I have is for a standard rotation pump, and I can't bolt up the new reverse rotation aluminum pump I need to use for my serpentine belt conversion (which I've already got all the parts for, spent some money on, and done a lot of work to get together.) I have a perfectly good mechanical pump I had planned to use with the Q-jet, but I can always go with an electric pump if I have to.
Here's some pics of the differences:
*New, reverse rotation pump timing cover from a 5.0 motor:
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=2421267457&category=33625
*Standard rotation pump timing cover with fuel pump mounting boss:
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=2421529092&category=33625
See how the water ports are angled in different directions? The mounting bolt patterns are slightly different also, if you look closely.
*Here's a cover from a 5.0 Explorer - yet another bolt pattern, must use a really funky pump:
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=2421041409&category=33625
72Sport
Try pawengineparts.com or summit racing and ask the Ford Racing Tech line. One or all of them will have what you want.
E
eBronc
Austin, Texas
Thanks for the tip, 72Sport.
Looking at the Ford Motorsport site, I came across the "universal" replacement cover they offer that has squared-off water inlet ports, so it'll work with either standard or reverse rotation pumps (or so they say - there's still a couple of bolt holes in the way). It ain't cheap either.
Damn, ain't nothin' ever easy.
74bronc
[quote author=eBronc link=board=5;threadid=19482;start=0#msg149505 date=1057083650]
[/quote]
It is said to figure out the price you think it will cost, figure out how long you think it will take, double both and you will be in the ballpark!!!! LOL
iwlbcnu
The 84-85 Mustang timing cover is reverse w/ the fuel pump mounting. Up to early 88 I think they still had the pump boss but you had to drill the arm hole out.
Look around cause someone makes a new one for $75
I know that the '85 stang 5.0 has the reverse rotation pump and it was carburated. That should be what you are looking for.
NoAZ68
Northern AZ
Hey e-Bronc,
I just completed this rebuild. Mine was an '85 351w 4bbl. I went w/ BCB's Bi-directional pump(comes out on pass. side). The problem that I ran into was that my timing pointer, harmonic balancer and pulleys would not work. I used my 289 parts (balancer, pulleys and timing pointer), and everything lines up now. I have to finish the wiring and mount my carb, but it looks like it will work and I can't wait to start it up. If only I could figure out the exhaust routing :) Good Luck!
E
eBronc
Austin, Texas
I took the easy way out and grabbed a reverse rotation cover off eBay for cheap. I know it'll work with the new water pump I have. I'll have to look at it when I get it and see if the fuel pump mounting boss is there and just needs to be drilled out and tapped for the bolts.
I'll probably just end up going with an electric fuel pump.
I'm working on exhaust routing right now, also. I'm using a old set of stock 5.0 Mustang shorty headers (they won't fit a stock EB with a 289 or 302 very well, but fit my 351W and 2" body lift fine). To connect with the collector on the headers, I got a set of "collector extensions" from Summit that are flared out at the end to mate with the ball-joint outlet of the headers, and have an "S" bend in them to help clear bellhousings and crossmembers. I had to cut and turn them a little to get just the routing I wanted, but for $20, they got me real close.
The passenger side pipe will run down alongside the inner passenger frame rail just above the trans crossmember all the way back to one of the Flowmasters mounted over the rear axle just in front of the gas tank.
The drivers' side will either run between the front driveshaft and the drivers' side radius arm frame mount, or maybe turn and cross just under the trans bellhousing, then turn and run paralell to the passenger side pipe over the crossmember, then back under the rear driveshaft and along the drivers' side frame rail under the emergency brake cable to the other Flowmaster. I'm thinking of this routing because I have future plans to clock the T-case up and move the radius arm mounts from the bottom of the frame to the outside so I can run a smooth belly skidplate even with the bottom of the framerails.
