rob wilson
I'm builiding up a 347 from a short block. Want to go with the Serp setup. Staying with a carb so I'll need a fuel pump mount on the timing cover. All the reverse rotation timing covers seem to have eliminated the fuel pump mount (since they are EFI). I don't want to use an electric fuel pump if possible so I'm curious to know what others have done to get around this. I have heard that there is a replacement water pump back plate that has "D" shaped water passage holes that will allow a reverse rotation pump to work on a standard rotation timing cover. Anyone know of a source?
Thanks in advance.
Thanks in advance.
