tire recommendations please
airman
I have been using MT baja claws and they were a good tire but I didn't like the fact that they are directional makes it hard to have a matched spare. I need new tires and figured i would get good old BFG All terrain's but for some reason 35x12.5x15 have been on back order for 18 months (govt contract). I put about 1K-2K per year and am not real worried about wear as they will get brittle side walls before I run out of tread. I just went out ans proved that.
75% street, 25% off road but I want to be ready off road. Prefer to keep under $300 per tire but not against a little higher.
So... any help, recommendations on brands would be appreciated, especially if there are any AZ guys left.
Thanks, Jeff
bmc69
I've run more different flavors of 35s than I can remember over the last 30+ years..but a few years ago I started running these Cepeks (Filly had them on her '79 Bronc first) and they are hands-down the best all-around tire I've ever run..and the quietest semi-agressive "mud terrain" tire by far. Wear is even and remarkably good too.
http://compare.ebay.com/like/330801333853?var=lv&ltyp=AllFixedPriceItemTypes&var=sbar
NYLES
BMC69 I Agree DC great tires but my 33's was 31.5 on 9 inch wheels.
I loves my Nitto mud graphlers.
bknbronco
North Metro, MN
Only better tire than a BFG all-terrain is there new mud terrains. More of a rock tire than mud but there better than there old mud design for sure. My mom runs 37" BFG muds on her rubicon all summer and i never heard her say she dont like them in the rain. Now the snow on the other hand....im not sure the muds would be as good as her 35" BFG all terains she runs in the winter.
I will also add that the BFG muds we have balanced out ausome and are pretty quiet on the tar until you air down.
SSDDBRONCO
Los Angeles
I have been looking at the Goodyear MT/R Kevlar. They placed 2nd in the 4wheeler mag against all the other good tires. Also based on reviews they seem to be one of the best all around tire.
Sent from my SPH-D710 using Tapatalk 2
airman
airman
It seems as if tires changed in the last 10 years. Would have never considered mud tires for road use but I'm seeing it as a bit more normal now. Thanks for the replies, all opinions good. I want to decide this week.
Jeff10
Indianapolis
Hey,
I'm running the Goodyear MT/r with Kevlar. Ran great this summer in the rocks, in sand and on the highway.
I posted a few weeks ago that on one of the Labor Day runs in Moab, the trail leader commented on first 6 vehicles running behind him all running those same tires.
There are a lot of good tires on the market. I don't know that you can really go wrong with the top rated tires.
Jeff
70_Steve
Old Guy
I switched from BFG A/Ts to SuperSwampers, and now to KM2s. The All Terrains were great. Drove great, very quite, and decent performance off-road. But I was ripping them up off-road. The KM2's aren't nearly as loud as the SuperSwampers, but they are the loudest noise in the Bronco at 70.
00gyrhed
boy this is oportunistic. I am looking at going to lt315/75/16. I currently run LTB 34X10.50X16 SS. They measured exactly 33" on 8" rims new and now measure 32" after 11,000 miles. I get good even wear rt to lt and frnt to back. The rubber is just too soft. Interco says 33.5 but they nailed the section width. I have run a lot of P255/85/16s over the years and they range in height from 33" to 34" and never match the manufacturerers specs. My experience is that all manufacturers lie about height then once they are mounted they know youi are not going to reject the tire over a 1/2-3/4".
I am leaning toward the Goodyear duratrack (supposedly 34.8") or the Dick Cepek MC (suposed ly 34.5) All a really want is a P255/86 but I HATE the BFGoodrich Mudterrain and will never buy another.
Anyone have expewrience with the duratrack?
Anyone know what the durtrack or Mud Counry actually measures on an 8" rim?
Greg_B
Cohutta, GA
Why would they measure differently on different rims?
The tire diameter cant get larger or smaller... the tread width cant either can it?
The only thing the rim width does is push the bead in or out.
Unless I am missing something I dont see how any measurements could change.
Greg
bronconut73
Thanks, Jeff
I have run the BFG muddys and all terrains. Love them both. One of our bronco brothers mentioned Dick Cepek FC II and they are an outstanding all around tire. But if I had my choice right now it would be the Mickey Thompson Baja MTZ's. I ran these on my F-250 (38.5" x 15.5" x 16") and was amazed by how quiet such an aggressive tire is on the road. Just unstoppable off road (and IMO best looking).
They are a little expensive but IMO worth every penny.
By the way these tires won the Peterson 4WD mud tire contest last year.
bronconut73
you are exactly right!
the manufacturing process has improved signifigantly over the last twenty+ years. from segment molding to produce far more round tires (better ride and balancing) to rubber compounds that wear better (ie harder) but still have good/safe traction (ie softer). the tire companies (or atleast many of them) have accomplished the best of both worlds.
you are one of thousands of guys who are considering buying mud tires that would not have in the past for all the compromises they represented for highway use in the past.
todays tires are safer, last longer, and come in more varieties than any other time in automotive history.
i cannot believe how quiet some of these aggressive mud tires are on the highway today.
00gyrhed
Greg
Height does change with rim width but it is very minor and in many tires not worth considering. I mainly want to get the section width on a 8" rim and HT to compare to the manufacturers specs. I had s et ot 10X31s 30 years ago when that was big that varied by over a half inch due to changes in rim width. If the manufacturer sets its rim with at a certian size changing rim size wider spreads the section and can reduce the diameter, like wise putting it on a narrower wheel reduces the section and can sometimes increase diameter. It all depends on the way the tire is constructed. These new fangled radials are affected less than bias ply tires were. Its the reason interco gave me for why my current SSs measured a full 1/2" less than the spec because I was running 8" and the spec was set up on 7". I didnt reall care I just want to rag on them because it has been my expereince that they all lie about how tall their tires are. I have seen tires labeled 33s that were less than 32" when mounted. My SSs are labeled 34s and measured exactly 33" I once bought a set of 35s that made like 33.75". I have had tires with the exact same metric designation vary by over an inch from each other, some much that one fit fine and another rubbed.
But alll I really want to know is how tall will the goodyear or dick cepek tires actually be on 8"ers. (Just it case they do vary) because I know that with my wheels a 12" section and 34" will not rub, but 12.5 and 35 might. I buit this to run 255/85s but the selection of that size is limited, and 315/85 is closest to that without going smaller.
BroncoBrandon
Im personally a Micket Thompson fan, I have the Baja MTZ's and I love them. Not too loud,Good on road manners and work well in rocks,dirt and mud. Alos a pretty good price.
I am also a fan of BFG Mudders and the Wrangler M/T's But both of these options are far more expensive than what I paid for the Baja MTZ's.
Airman: If you need a good contact for tires PM me and I will give you a number for a good friend of mine that is local and owns a mobile tire and wheel company in the Phoenix area.
Tedster100
Chairman of the Bored
I tried a set of the new General Grabber's this fall because I wanted an aggressive tread but less noise. So far I've only had them on the road but they handle way better than the previous set of General MT's I had on and there is very little noise even at highway speeds. They're designed for desert racing so I'm not sure how good they will be in the mud and snow but I can't wait to find out. 33x12.5x15 mounted were around $1,090 two months ago. My spare is a MT I got cheap.
bknbronco
North Metro, MN
Just remember that the BFG mud tires will be horrible in the rain and snow compared to a allterrain BFG. I run some 10 year old worn down BFG muds but i only drive when its not raining or snowing. You couldnt get me to put muds on a daily driver truck that got me to work rain or snow, but on a fair weather bronco the muds would probably win because of look factor as well as that possibility i might get the urge to bash some rocks.
I had 35" BFG muds on my excursion and even pulling a 16' enclosed trailed at highway speeds in rush hour during a blizard i always knew the BFG all terains were a predictable tire and would hold up there end of the bargain. If id been running muds i probably would have called it a snow day!
airman
airman
Thanks for all the help guys, ended up with KM2's and they seem pretty good so far, hasnt rained here in a month so havent got to try that out yet.
bronconut73
Great decision.
Regarding rain, hey they're a mud tire, you simply drive a little more carefully in the rain, especially in our eb's. KM2's are a great tire and worth any compromise you might experience in the rain.
asinor
Tulsa, OK
I'm going to try the Cooper Discoverer STTs next time around. I have a friend that has nothing but good things to say about them for heavy on-road/trailer and medium offroad use.
