One of my top favorite colors for an EB!
But I digress...
Typically the drop brackets flex even when bolted as tight as you can get it. This promotes a very slight wandering, which isn't horrible, but added to anything else and it's pretty noticeable.
However, your particular design (still pretty sure it's Rancho) is not as prone, simply because it's not dropped down as much. Hence less leverage applied by the bar.
Frankly, if you're going to stick with the stock pitman arm, at a minimum I'd just take it back off.
However, here are the possible steps towards better steering with a lifted Bronco. Not necessarily in any order. We can then discuss which ones are better. Or "better" in the Bronco world!
1. Lose the current bracket and drive as-is. (works for some with 2.5" lifts, but not always the best solution)
2. Lose the bracket and add an adjustable trackbar and draglink to re-center the axle and re-center the steering box with the wheels.
4. Get a larger bracket from one of the vendors and match that with the dropped pitman arm. (this is my vote for "best" but as always, your results may vary)
5. All of the above. New drop, arm, draglink and trackbar. Yes, it's more money and is not always an absolute necessity for a 2.5" lift. But all of those parts are allowing you to fine-tune your steering to your new higher-than-stock position for best road manners.
Rancho designed a minimalist drop bracket because they did not have a matching pitman arm to keep the geometry correct with their re-purposed 3" lift. (re-purposed from the 1.5-2" lift for the F150 that is) and never recommended the use of the full-size drop arm with EB's like they probably could have.
With manual steering, you likely have more play than a comparable power setup. You also have less resistance to input from the wheels and tires. You also have less tolerance for the positive caster numbers we all strive for. It also is more sensitive to lifts creating a vague steering feel.
And to add insult to injury, it will likely react completely differently to tire pressures than would power steering. You can tolerate more pressure because it helps with steering effort, and is not prone to being as squirrelly (depending on the tire of course) as a comparable situation with power steering.
Or not...
And since yours is no longer a simple quick question and answer, you might just start a new thread and post up a link to it here for us to follow.
With your manual steering still, not everything that is important to yours is necessarily pertinent to the original poster's discussion.
Besides, that'd be a great excuse to show us more pics or your nice looking rig!
Is that Boxwood Green, or a slight variation on that theme?
