Track Bar Bracket - Coil Cup Clearance Issues
Ol'Blue
Finally got my longer travel shocks to go with my Duff Radius Arms but now I have a clearance problem between the frame mounted track bar bracket and bolt interfering with coil cups. See pics with contact points.
The track bar bracket is large and I think stock on 76/77s.
I thought I might be able to screw in the heim joint on the rear of the radius arms to draw the axle back some but they are all the way in.
I can think of the following options:
Grind down the track bar bracket and take a small section of the coil cup out but don't like that idea too much.
Drill a new hole in the track bar bracket and raise it up, then cut the lower section off, but this would require a track bar riser on the other end. Would this require me going tie rod over to maintain the geometry OR is it okay as long as the drag link and track bar remain parallel? This should work but this thing drives great and concerned with opening a can of worms.
Any other ideas and or thoughts on these?
Thanks!
bronconut73
I am TRU with an axle riser bracket.
The steering feels tighter. It took some getting used to; it is definitely different....
My drag link and track bar are parallel.
I also replaced all of my bushings at the same time, so it may be a little tighter because of that.
savage
Bronco Nut
Renton
I think I would grind a little of the edge of the drop bracket? I have a drop bracket and the coil cups and no interference, but I do have stock arms.
Ol'Blue
Ol'Blue
Is track bar adjusted properly, as in is the axle centered?
I didnt even think of that. I did some quick measuring and it looks like axle could be a little to the passenger side and that could be enough. When I have more time tomorrow, I will take a better look. Thanks!
Apogee
Tangent, OR
If the axle is centered, could you just shift the coil cups outward slightly?
I tweaked a lower coil cup on my '77 F150 the same way, interfering with the track bar mount, but had to practically roll the rig to make it happen. I couldn't recreate it with a forklift, springs in or out.
I'd just notch the spring cup and call it good.
If you determine that the axle is too far forward due to the installation of the longer radius arms, then cutting the rear mounts off and moving the whole assembly rearward would be the right thing to do. But being such a huge amount of work for a small gain, that would likely be the last item on anyone's list.
I don't think you would weaken the trackbar bracket over much if you did trim a little off, but just how much is needed? I'd rather cut the bucket than the trackbar bracket.
Not sure moving the axle to the passenger side won't actually make it worse. Seems that to offer more clearance for the curved bucket you'd want to move it more to the driver's side. But either way, you're still looking for a centered axle. Not one that is shifted to one side to avoid interference.
Doesn't look like the interference is deep enough to require dire fixes. See what it would take to notch the cup. And lightly reinforce it if the cut is deep. Doesn't look like that would be needed from the pic, but hard to say until you dive in.
Good luck.
bronconut73
I had to move my Passenger radius arm mount back a 1/2" because my coil was touching the front of the coil bucket and my arms were adjusted as short as they could go. It's done but there was another option....Leave the mount in place and cut a 1/2" off the end of the arm then screw the heim back in.
migs
If it's still hitting after centering the axle then I would suggest looking into moving or shifting the coil cup slightly.
One thing I noticed with those cups is the mounting holes are centered, not offset like the factory ones. I tried and would not have been able to bolt them on without grinding things as they did not clear my track bar riser or drivers side bump stop mount. this issue is what lead me to just make my own, with a slightly smaller over all diameter and offset for the same placement as the factory ones.
Ol'Blue
Ol'Blue
Well I was able to get one turn in on the heim joints to gain me about 1/8". So that should help a little. When I have more time tomorrow, I will check and center the axle. Then grind the cup and bracket if I have to.
Ol'Blue
Ol'Blue
Axle is center nicely so ground some off the coil cup and bracket. Hopefully that will do it, if not Migs may be getting a call for new cups.
