turn sifnal wireing help
sean lalley
biloxi
i put a column out of a 78 van in my bronco and need to know what wire to hook to what wire for the centech harness any help would be great
thanks
sean
sean lalley
sean lalley
biloxi
ok this is what i have so far
ternimal on centch harness and what it does / color of wire from column
p stop switch / green
n left stop switch / orange /blue
m right stop switch/ green/orange
l turnsignal flasher / light blue
k hazard flasher / white/red
j right front turn / white/blue
h left front turn / green /white
i have tried to meve them around and this is the best i can get
i have brake lights and flashers but not turn signals
when i move l and k i get nothing
this is about to drive me nuts and i dont understand it
any ideas as to what i can check
thanks
sean lalley
sean lalley
biloxi
they say a pics worth a thousand words
so maybe this will help
Beardawg
Swannanoa, NC
are you sure your switching 12 volts and not grounds what i've seen is the bronco wiring switches 12v+ and some other vehicles i've worked on switch the gound onto the circuit. try jumpering 12v + to your centech harness and see it the turn signals work the try and trace it with a multimeter.
shatra04
GREAT FALLS,MT
ok, lets see... if you look at your signal switch from the front you will see two bigger gauge wires to the right, thoughs are for your horn. Next, if you look to the left of the switch, you will see two smaller gauge wires. The one on the right is your stop switch or terminal "P" on the centech harness. The one on the left is your turn signal flasher or terminal "L"... Now, flip over the signal switch and there are four wires on the right side. Two on top and two on the bottom... The top left is for your Pass. stop lamp or terminal "N"... The bottom left will be your terminal "M" or driver stop lamp. The top right is left front turn lamp or terminal "H"... The bottom right will be terminal "J" or right front turn lamp. The two bigger gauge wires for the horn are as follows; the top is your Terminal "D" or horn switch power IN and the bottom is either terminal "E" (if you have no horn relay being used) and its for horn switch OUT to horns... If you are using a relay, you would put that wire into terminal "G" instead...
I hope this helps, i just put in a new signal switch in my 71'... mine was for a 68'-73' bronco but the wires didnt match up so i had to figure out what went were... i ended up having everything work but my brake lights... I ended up having a blown fuse.:) its always something!
Viperwolf1
electron whisperer
I have no idea what the '78 color code is and only a rough idea of the centech colors. I would use an ohmmeter on the column to match colors with function. For example: Brake light input has continuity to both left and right turn/brake wires when the turn signal is off. When the left turn is on, there is continuity to only the right turn/brake wire. Hazards have continuity to all 4 turn signals. Front and rear signals have continuity to each other when the turn signal is on.
