Turn signals activate flashers??
WYBRONCO
Casper, WY
I’ve been a longtime spectator (quite a few problems solved from all the great input here) but first post. 1975 automatic with a Painless harness - problem is when I turn on both L&R blinkers, the hazards come on. When I activate the hazard switch they work fine as expected. I swapped flashers and replaced both with new - no change. Chased all (I think) fuses and haven't found any blown. I pulled the steering wheel & replaced the turn signal harness with same result. All 4 lights function when flashers are activated as well. I did the build ~10 years ago and didn’t have this problem until it surfaced a few years ago Need some help on where and how to trouble shoot please - thanks in advance for any input you can provide.
SLOWnEASY
San Diego, Ca.
Sounds like a short. Check the rear brake bulbs. or pull one bulb and leave it out and see if it behaves any differently. Then put that bulb back in and pull the other bulb.
W
WYBRONCO
Casper, WY
I just tried replacing all 4 bulbs and no change. New wrinkle - just discovered I have no brake lights either. Headlights, running lights and hazards all good. Blinkers fire hazards and no brake lights.
The recent column harness change may be complicating things. I'm guessing you had other problems and maybe added to it by changing more parts.
I would take out all 4 bulbs at once. The only thing left will be the indicators on the dash, and those won't have enough load to trigger the flasher. Then go around and put one bulb in at a time, checking everything as you do. As you power the bulb, inspect which filaments are lighting up. Bad grounds will chase a ground in the opposing circuit partially powering it up.
As for the brake lights not working. I start at the brake switch. Does it have power going in? How about switched power coming out? If it is functioning correctly, the next stop is the turn switch. Something you just mentioned you worked on.
