- Jul 30, 2001
- 14,803
Thanks Pat,I had mine done a www.performancecryogenics.com. Ask for Dean, he is the owner and real good guy. Tell him that I said "Hi" if you talk to him. Are you going to respline them to 35 spline? If so, you need to find another long side rear axle shaft. The short side rear shaft isn't large enough (diameter) to respline to 35 spline. You can get 31 spline out it though.
I've been researching this and I must of read your build thread more than a dozen times. I'll be calling Dean about this and his H1 wheels this week, Seems like his website doesn't load.
I may go with a 31 spline cut because I got the diff and I won't need to get another axle shaft, Mac at Exaxt said they are in demand and getting scarce. This raises a question that I asked previously, "Aren't the axle and gear side specific?" I thought the helical gear are cut a certain way for each side..
I'll have the answers as soon as I open up the other end. I got today to go and work the front axle at the shop so we can get it home.
Thanks again,
Honorio
edit... I see that the end gear is removable on the axle shaft...
