So I finished up all my EFI wiring last night so I moved on to replacing the Speedo cable
Ordered a new cable (couple inches longer than stock) from BC item 22-00122 "This cable is 83" long. It threads on to the stock Bronco speedo head and plugs into a Ford VSS that you insert into the Dana 20"
I have a Ford VSS for a 95 Stang (I'm using a 95 Stang ECM) and there is no way the BC cable is going to fit the VSS. I noticed the VSS sold on the vendors sites are all "blue" and mine is not.
Did I screw up and buy the wrong parts? I've read about drilling the VSS and using stock cable but this cable is supposed to work without drilling and my stock cable is junk.
What VSS sensor do I need? Clearly not the 95 Stang.
Tim
Tim
