Wacky wiper behavior
chuzie
77 with intermittent setup.
It has worked flawlessly for years. Now it on, runs in LOW regardless of switch position and will not stop even in the OFF position. Sometimes if I actuate the switch 50 times, it may actually park.
Initially I thought it was the park contact in the motor, but that wouldn't explain the lack of response from the other positions.
Then I thought it was the intermittent box, but that doesn't explain the lack of high and low.
The only logical conclusion is the dash mounted switch, right?
When the intermittent, then the slow speed went out on my '79, it was the switch.
New one cured all the little problems it had developed over time.
Always check your wiring of course, but the switches do go bad.
chuzie
chuzie
Replaced the switch and the intermittent box. Still have the problem so it must be something on the motor or a wiring issue that has developed.
'77 wiring...
I get the following numbers
. Off Low High
R 12 12 12
W 0 12 12
BL 0 0 12
BK 0 0 0
I have continuity between motor, bracket, and ground.
Thoughts?
chuzie
chuzie
Gotcha. I will start tracing that. Gonna look at park contacts in motor too.
Thx.
Viperwolf1
electron whisperer
'77 wiring...
. Off Low High
R 12 12 12
W 0 12 12
BL 0 0 12
BK 0 0 0
Thoughts?
Red is ok.
White should only have 12V in LOW or in OFF until the wipers park.
Blue looks ok. (only have 12V in HIGH)
Black should be 0V when the wipers are parked and 12V when unparked.
chuzie
chuzie
Pretty sure I took those readings with motor disconnected. Let me take them again with it connected and I can see if it being in park changes things.
Awesome diagram. Thanks.
chuzie
chuzie
Tore the motor apart. Looks like the plunger is not extending far enough to make contact with the park switch and I don't think I can accurately bend the contacts.
Thinking about drilling and taping the top of the plunger and installing a tiny set screw to allow for fine adjustment. The only problem is I am dealing with 40 year-old plastic so i only get one shot before I have to buy another motor. ;(
chuzie
chuzie
I opted for a less destructive / less risky solution. Applied some JB Weld Steel Stick to the tip of the plunger. After setting for an hour, I used a file to remove material until the park switch was dialed in perfectly. JB Weld is not typically my first choice but considering this is a simple compression action rather than torquing, I feel confident it will last.
While celebrating that little victory, I snapped one of the housing bolts. WHY ARE THEY ALUMINUM!?!?!?
Fixed that and mounted the motor. The issue hasn't duplicated so I hope it is fixed.... for now.
