My 347 has been fun ! You won’t regret itI broke the motor in mine yesterday. Time for the 347 build
That’s some pretty work on that console.Finally got my console bolted in with my amp mounted to the bottom. Installed a new drag link and removed the steering stabilizer. Drove fine with no death wobble for the two mile test drive to the gas station. Maybe I can leave it off. Steers better without it. Got exhaust tips installed. And finally got around to cutting some metal for my custom 3" body gap filler for the front. Then got sidetracked while I had the plasma torch going and spent the rest of the day cutting up scrap metal to repurpose on a long list of DIY builds. I watch way too much YouTube. View attachment 892815 View attachment 892816 View attachment 892817 View attachment 892818
Yes I have driven that combo before. ( crazy Horse ). It was a blast to driveMy 347 has been fun ! You won’t regret it
Dan Carr custom builds them locally here in Oregon, pm me if you’re interested and I will send you his info.More on this center console please. I'm getting very close to that stage and am looking for ideas.
What size tire are you getting? I paid $1200 for five 33" mud terrains mounted and balanced. Yes they are real expensive these days.
Just trying to figure out how to get all the cables out to the spots they belong. View attachment 892148
Beautiful. What color is that?Got the grille painted yesterday and installed today, also spent prolly 5 hours on getting twin stick cables ran and hooked up. View attachment 892293
Looks like boxwood very nice job and the grill paint good colorBeautiful. What color is that?
It’s my take on Boxwood green, a custom mix.Beautiful. What color is that?
No death wobble but the steering was all over the road. Lot of slop from the worn drag link. It would flip back and forth on the tie rod and the truck would dart slightly in the direction you turn. It just felt loose. At the same time the steering was harder than I liked with the stabilizer. All seems fixed now, but I need to get a lot more driving time to make sure. Will be installing a riser bracket on the axle soon, I think a better angle on my track bar will help too. I have 3.5 WH lift.Did it have Death Wobble before? Is that why the new tires?
Got quite the steep angle on the links still, it looks like from here at least. How high are you lifted?
Anything planned to get the angles down a bit?
Drove it!
Now it’s back in the garage installing the seat relocation bracket to move the oem seat back 2”.
Hooked up the trailer to go to the Pinedale shopping mall for a turkey. Hope it goes better than last year.
Interesting grill. what's that hood going to look like?Painted the inside of the grill and then did a Hollander's version of a front end alignment.
View attachment 892879 View attachment 892880
I thought I had skipped a tooth on the timing chain. I started tearing it down and found a suspect crank trigger wire. I already had the new gear and chain set so I went ahead and took the cover off. It had not jumped a tooth but it needed a chain pretty bad. I ordered new pigtails for the cam and crank position sensors. Also picked up a new crank sensor. Pretty sure my broken wire is the cause. It was making intermittent contact causing the motor to run crappy. So I will throw these parts at it and hope for the best. I was on borrowed time with the chain so this was a good thing, right?I broke the motor in mine yesterday. Time for the 347 build
