What have you done to your Bronco today?
edones06
Looks like it worked, blew the wheels off and the hood up;D
Yea its gettin a make over. Its on tons allready but getting streched and linked front and rear and a very drastic fender triming to clear 42's with around 4" of lift or so. It got a ls full manual 350 turbo and 203/205 and a full cage and the power windows and power sunroof still work. Its a neat ride
rcmbronc
Tomah WI
My Bronco had been kind of running poorly. It would act as if not enough fuel pressure on and off. I decided to change the fuel filter and the regulator. Test drove it after that and ran even worse. SO pulled codes and said MAF issue. Took a look at it and saw that I must have un plugged the MAF at some time so plugged it back in and all good. Seems to run good now.
sprdv1
REBEL
sounds awesome man.. Gonna be bad azz...
NYLES
Sprayed the door jams! Removed tube doors...till I get around to skinning them.
76YETI
KC METRO
Installed new BH Ceramic Headers and a BC-Style 2 into 1 exhaust...sounds good! I had headman headers that I measured at over 500 degrees, checked the new ceramic headers and they were at 230!
5001craig
Leaving for our annual vacation to SLSD soon. Funny how deadlines are effective.
Change TC fluid, removed rear TC support (TMR) as recommended by Atlas and swapped engine oil filter to a better one (Purolator Boss PBL30001).
And I took her for a spin. ;D
edones06
Vincen
Been working on repairing the front clip. Repaired the core support, new inner fenders, wheel houses and diy kick panels. Everything is screwed together and in the meantimei wil be repairing and de rusting the inside of the hinge pillars. Fabbed up two hinge plate retainers. Plan to use Eastwood fast etch followed by rust encapsulator before closing them back up
DonaldDouchebag
I polished a set of 15" x10" slots tonight. I'm on the way to getting my truck back on the road.
In the past week I swapped in a 4 turn PS box and went to a dual return pump and a PS cooler that uses a spin-on filter. I installed a Hellwig front swaybar, 7 degree C bushings, a new Odyssey battery, a fancy new air filter, a new fuel pump and lines, and an extended rear brake hose and new hard lines. I also installed new 9/16" ubolts, heavy duty spring plates, and those Off-road Design zero-rate blocks to move the rear axle back an inch and a half.
I'm waiting on parts to rebuild my rear drums. Of course I had one bad axle seal,too. I didn't have any of the self adjuster parts which is super cool. I was manually adjusting them for years. :(
Montoya
More welding
Got a little more welding done on my track bar and front sway bar mount. I still have to put the bottom plate on but considering how crude I'm making the brackets, once welded they aren't looking too bad.
sprdv1
REBEL
First time out the garage in a little while
Cruised down to the damn for a few minutes. Watching the peeps partying
BronCowie
Old Timer
Vancouver, WA
First time out the garage in a little while...
It's about time Bro... happy for you.
I put mine on a tow truck yesterday off to a transmission shop (this work is way above my pay grade), went in today for a consultation. I'm going for a full-blown rebuild :p... got my money's worth out of this C4 that was last rebuilt by the PO ~27 years ago. :cool:
NGABronco
N. GA now South Carolina
Pressure washed the crawler, gave "Stretch" and the Super Duty a bath!!! We all clean now!!!!;D;D;D
DonaldDouchebag
Donald that's a nice weeks work dude! :cool:
I've been thrashing hard on it in hopes that another summer doesn't slip away!
I still want to do hydroboost and a 1 inch body lift. I have all the parts waiting and ready to go. I just need to stay motivated. Oh, and I have some new headers and the stuff to do a super single exhaust. We'll see if my poor welding skills can make it haplen.
sprdv1
REBEL
We can only do so much right.. I been procrastinating on a radio for years..
Got the box/cage mount speakers, (FRANKO), just need to determine what radio I want now plus amp, etc....
